Author Topic: Making ULX Ranks apply to the IsAdmin() Class  (Read 6113 times)
Offline Promptitude
« on: January 04, 2016, 12:30:14 pm »
How would I go about making certain ULX ranks apply to the IsAdmin() class?
Re: Making ULX Ranks apply to the IsAdmin() Class
« Reply #1 on: January 04, 2016, 12:36:38 pm »
If I remember right, make the group inherit from the default "admin" group.
Same goes for "superadmin" and IsSuperAdmin().
Offline Promptitude
« Reply #2 on: January 04, 2016, 12:43:29 pm »
I found this in the Garry's Mod Github.
    Desc: Returns if a player is an admin.
function meta:IsAdmin()
    if self:IsSuperAdmin() then return true end
    if self:IsUserGroup("admin") then return true end
    return false
« Reply #3 on: January 04, 2016, 02:10:27 pm »
promptitude, what decicus says is correct.
ULib, and therefore ULX, allow inheritance.
If you set any group to inherit the admin group in your group setup, IsAdmin will return true.
Be warned however, Gmod's admin access allows much control over a server.
