Author Topic: Uppl -- Ulysses Per Prop Limit. Restrict specified props to a certain number!  (Read 298168 times)
Have you ever wanted to restrict players to say, 10 explosive barrels at a time? Sick of people making 50 bridges at a time? If so, Uppl is for you!
Pronunciation: "Up-ehl"
Installation:
Extract the uppl folder to garrysmod/addons
Insert limits into a config
Usage:
uppl_add <model> <number> -- Limit a prop to a certain number.
uppl_disabled <0/1> -- Enable/Disable Uppl on the fly.
uppl_affectadmins <0/1> -- Defaults to 1, set to 0 so admins aren't affected.
FAQs:
Q: Does the normal duplicator, Adv Dup, and Overload's Stacker support this?
A: The first two work out of the box with Uppl, but the Stacker STOOL needs some modification. See this thread for modification instructions.
Suggested Limits:
// Add this to your server.cfg or ULX configs (IE, ULX per map config or per gamemode)
//Prop Limits//
// Explosives
uppl_add models/props_c17/oildrum001_explosive.mdl 10
uppl_add models/props_junk/propane_tank001a.mdl 10
uppl_add models/props_junk/gascan001a.mdl 10
// Misc
uppl_add models/props_c17/utilitypole01d.mdl 16 // Restricted because some moron tried (but failed) to crash the Ulysses server with this.
// Phx explosives
uppl_add models/props_phx/misc/flakshell_big.mdl 10
uppl_add models/props_phx/ww2bomb.mdl 10
uppl_add models/props_phx/torpedo.mdl 10
uppl_add models/props_phx/mk-82.mdl 10
uppl_add models/props_phx/oildrum001_explosive.mdl 10
uppl_add models/props_phx/ball.mdl 10
// Big/annoying
uppl_add models/cranes/crane_frame.mdl 4
uppl_add models/props_buildings/building_002a.mdl 1
uppl_add models/props_buildings/collapsedbuilding02b.mdl 4
uppl_add models/props_buildings/collapsedbuilding02c.mdl 16
uppl_add models/props_buildings/project_building01.mdl 1
uppl_add models/props_buildings/project_building02.mdl 1 // I do believe this is the biggest prop in the game.
uppl_add models/props_buildings/project_building03.mdl 1
uppl_add models/props_buildings/project_destroyedbuildings01.mdl 1
uppl_add models/props_buildings/row_church_fullscale.mdl 1
uppl_add models/props_buildings/row_corner_1_fullscale.mdl 1
uppl_add models/props_buildings/row_res_1_fullscale.mdl 1
uppl_add models/props_buildings/row_res_2_ascend_fullscale.mdl 1
uppl_add models/props_buildings/row_res_2_fullscale.mdl 1
uppl_add models/props_buildings/watertower_001a.mdl 16
uppl_add models/props_buildings/watertower_002a.mdl 8
uppl_add models/props_canal/canal_bridge01.mdl 4
uppl_add models/props_canal/canal_bridge02.mdl 4
uppl_add models/props_canal/canal_bridge03a.mdl 10
uppl_add models/props_canal/canal_bridge03b.mdl 5
uppl_add models/props_combine/combine_citadel001.mdl 1
uppl_add models/props_combine/combineinnerwallcluster1024_001a.mdl 4
uppl_add models/props_combine/combineinnerwallcluster1024_002a.mdl 4
uppl_add models/props_combine/combineinnerwallcluster1024_003a.mdl 2
uppl_add models/props_wasteland/rockcliff_cluster01b.mdl 8
uppl_add models/props_wasteland/rockcliff_cluster02a.mdl 8
uppl_add models/props_wasteland/rockcliff_cluster02b.mdl 8
uppl_add models/props_wasteland/rockcliff_cluster02c.mdl 8
uppl_add models/props/de_nuke/storagetank.mdl 3
uppl_add models/props/de_train/biohazardtank.mdl 0 // This gibs and never goes away
// Phx big/annoying
uppl_add models/props_phx/misc/big_ramp.mdl 2
uppl_add models/props_phx/misc/small_ramp.mdl 4
uppl_add models/props_phx/playfield.mdl 4
uppl_add models/props_phx/huge/tower.mdl 1
uppl_add models/props_phx/huge/evildisc_corp.mdl 1
// Gmow3 big/annoying
uppl_add models/trailer1.mdl 4
uppl_add models/ramps/ramp1.mdl 4
uppl_add models/ramps/ramp2.mdl 2
Download: http://ulyssesmod.net/archive/Uppl-v1_0.zip
Want to suggest a model to add to our default limits? You MUST give us the full model AND a picture of what it looks like in game AND why you think it should be restricted.
« Last Edit: June 08, 2007, 11:22:18 pm by Megiddo »
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
Dave Chuh uppl?
Dave Chuh uppl?
Nope GD...
Uppl, its not a drink (Snapple)
We tried different names. It's all Megidd's fault for going with my bad suggestion. :P
    • BlueFire
No no, it sounds like Dave Chapelle.
Offline atomicspark
-snip-
You forgot a value for citadel. You'll get the "You need at least two arguments for this command." error.
So change
To
Fixed. Thanks!
Offline Chironex
  • Formerly known as Kyzer
I haven't tested it yet, but this look awesome. I hope it works! No more people crashing our server with huge/annoying props :)
Thanks.
But i have one question : where to find server.cfg? do you mean server_cfg.txt , from the garrysmod/cfg folder ??
« Last Edit: July 03, 2007, 09:05:38 pm by Kyzer »
Offline atomicspark
I have been working all day testing which props cause enough lag to bring the server to a standstill. This includes collisions, physics, and props that spawn inside itself. This does not include props that give major fps lag or just plain messy props. I'll update this list after I finish each section.
Todo: CS and DoD.
// Useful Construction Props
uppl_add "models\cranes\crane_frame.mdl" 10
uppl_add "models\props_c17\bench01a.mdl" 10
uppl_add "models\props_c17\chair02a.mdl" 10
uppl_add "models\props_c17\fountain_01.mdl" 10
uppl_add "models\props_c17\furniturechair001a.mdl" 10
uppl_add "models\props_c17\furnituredrawer002a.mdl" 10
uppl_add "models\props_c17\furniturefireplace001a.mdl" 10
uppl_add "models\props_c17\furnituretable003a.mdl" 10
uppl_add "models\props_c17\furnituretoilet001a.mdl" 10
uppl_add "models\props_c17\gate_door01a.mdl" 10
uppl_add "models\props_c17\gate_door02a.mdl" 10
uppl_add "models\props_c17\gravestone_statue001a.mdl" 10
uppl_add "models\props_c17\lampshade001a.mdl" 10
uppl_add "models\props_c17\lockers001a.mdl" 10
uppl_add "models\props_c17\metalladder001.mdl" 10
uppl_add "models\props_c17\pulleyhook01.mdl" 10
uppl_add "models\props_c17\utilitypole01a.mdl" 10
uppl_add "models\props_c17\utilitypole01b.mdl" 10
uppl_add "models\props_c17\utilitypole01d.mdl" 10
uppl_add "models\props_c17\utilitypole02b.mdl" 10
uppl_add "models\props_c17\utilitypole03a.mdl" 10
uppl_add "models\props_canal\canal_bridge01.mdl" 10
uppl_add "models\props_canal\canal_bridge02.mdl" 10
uppl_add "models\props_canal\canal_bridge03a.mdl" 10
uppl_add "models\props_canal\canal_bridge03b.mdl" 10
uppl_add "models\props_canal\canal_cap001.mdl" 10
uppl_add "models\props_interiors\furniture_chair01a.mdl" 10
uppl_add "models\props_interiors\furniture_shelf01a.mdl" 10
uppl_add "models\props_interiors\furniture_vanity01a.mdl" 10
uppl_add "models\props_junk\pushcart01a.mdl" 10
uppl_add "models\props_junk\trashdumpster02.mdl" 10
uppl_add "models\props_trainstation\mount_connection001a.mdl" 10
uppl_add "models\props_trainstation\pole_448connection001a.mdl" 10
uppl_add "models\props_trainstation\pole_448connection002b.mdl" 10
uppl_add "models\props_wasteland\coolingtank02.mdl" 10
uppl_add "models\props_wasteland\horizontalcoolingtank04.mdl" 10
uppl_add "models\props_wasteland\kitchen_fridge001a.mdl" 10
uppl_add "models\props_wasteland\laundry_cart001.mdl" 10
uppl_add "models\props_wasteland\prison_celldoor001b.mdl" 10
// Useful Comic Props
uppl_add "models\props_c17\chair_kleiner03a.mdl" 10
uppl_add "models\props_c17\chair_stool01a.mdl" 10
uppl_add "models\props_c17\playground_carousel01.mdl" 10
uppl_add "models\props_c17\playground_jungle_gym01a.mdl" 10
uppl_add "models\props_c17\playground_swingset01.mdl" 10
uppl_add "models\props_c17\playgroundslide01.mdl" 10
uppl_add "models\props_c17\statue_horse.mdl" 10
uppl_add "models\props_combine\combine_monitorbay.mdl" 10
uppl_add "models\props_combine\combinethumper001a.mdl" 10
uppl_add "models\props_combine\combinethumper002.mdl" 10
uppl_add "models\props_combine\combinetower001.mdl" 10
uppl_add "models\props_junk\plasticcrate01a.mdl" 10
uppl_add "models\props_lab\kennel_physics.mdl" 10
uppl_add "models\props_lab\reciever_cart.mdl" 10
uppl_add "models\props_lab\securitybank.mdl" 10
uppl_add "models\props_lab\servers.mdl" 10
uppl_add "models\props_lab\workspace001.mdl" 10
uppl_add "models\props_lab\workspace002.mdl" 10
uppl_add "models\props_lab\workspace003.mdl" 10
uppl_add "models\props_lab\workspace004.mdl" 10
uppl_add "models\props_trainstation\payphone001a.mdl" 10
uppl_add "models\props_trainstation\traincar_seats001.mdl" 10
uppl_add "models\props_vehicles\carparts_axel01a.mdl" 10
// HL2 Vehicles
uppl_add "models\combine_helicopter.mdl" 10
uppl_add "models\props_trainstation\train005.mdl" 10
uppl_add "models\props_trainstation\train002.mdl" 10
uppl_add "models\props_vehicles\tanker001a.mdl" 10
//Special Effects
uppl_add "models\props_foliage\oak_tree01.mdl" 10
uppl_add "models\props_foliage\tree_deciduous_01a.mdl" 10
uppl_add "models\props_foliage\tree_deciduous_02a.mdl" 10
« Last Edit: July 24, 2007, 12:24:29 am by atomicspark »
Good list! Nothing from PHX or GMOW3?
Also, I'm planning on making an anti-spammer in the next version. My idea is to ignore dupes and stacks and only make it work for direct spawning. (Yah I realize this is sorta cheezy but I really don't see a way to make it effective on stacks and dupes)
Offline atomicspark
Chaussette's Spam Protection script, worked wonders for anti-spamming but it disallowed the ability to use adv duplicator. For this reason only, I couldn't use it on my servers. When I used it, anything more then 1 sec delay pissed off the builders. Setting it to .5 seconds seemed to be a good compromise but you can still spam a server with that. I ended up seeing no point in having a spam protector since most spams will be caught by an admin anyways. Just look how PHPirate bans many a day just buy looking at his logs. Don't get me wrong, Uppl is very nice for keeping a server stable. I just think it would be more useful as a limiter then a spawn delayer. Just my $0.02.
And for the Uppl list, I'll work on DoD and CSS later. I'm taking a break for now. I probably wont test the add-on props, you seemed to nail the bad boys in that group anyways. Remember my list is for stability only, not annoyance factor. ;)
Offline Chironex
I had problems with some of these limits not working. I discovered that after a certain amount of these lines, others are not executed. Before these restriction lines, i have a few (say 50) addForcedDownload commands. If i disable these forced download (also what you mean Forced (as people can still avoid to download them with a concommand that i can't remember) ?), all is working again.
I've put all the lines into the ulx/lua/ulx/configs/server.ini, maybe that's the problem? Don't you have any problem with many commands being executed at server start ?
I actually stick it in server.cfg, and there's no problems. I'll have to try putting it in server.ini, don't know why it would be giving you any trouble though.
Offline Avien
Do i have to enclose all of these commands in "" in order for them to work?
« Last Edit: August 03, 2007, 02:15:48 pm by Avien »
The model part yes
