Author Topic: Trouble with maps  (Read 8511 times)
Offline GabrielRF15
Trouble with maps
« on: June 02, 2007, 03:57:04 pm »
I already installed ULX v3.10, pretty good admin mod btw...
I've edited all these lines from server.ini
ulx votemapAddmap gm_castlewarfare
ulx votemapAddmap gm_construct
but when I type !mapmenu it shows me all these maps that I've edited, plus the CS:S server ones...
(http://img507.imageshack.us/img507/6189/gmconstruct0000dc8.jpg)
How the F*** can I remove those CS:S maps and just put the gmod ones into this list?
Re: Trouble with maps
« Reply #1 on: June 02, 2007, 04:13:54 pm »
Holy CRAP that's a lot of maps! This bug has been reported (http://ulyssesmod.net/bugs/view.php?id=92) and will be looked into as soon as I get my computer back.
Offline spbogie
« Reply #2 on: June 02, 2007, 05:30:46 pm »
Megiddo,
Although the ulx votemapAddmap command isn't working, I don't believe that's the problem here. Unless I'm mistaken ulx votemapAddmap is not designed to remove the maps from the maps menu, but just remove them from the ulx votemap list.
Side Note: We should really add scrolling to the maps menu
GabrielRF15,
As far as the CS:S maps go, they show up because Garrys Mod mounts everything from CS:S.
Gabriel
« Reply #3 on: June 02, 2007, 06:02:58 pm »
THANK YOU SPBOGIE!
the mounting of cs:s content, can be divided? I mean, just props and weapons? can i restrict the maps from mounting?
Offline GabrielRF15
« Reply #4 on: June 02, 2007, 06:32:07 pm »
Sorry for both topics, I forgot to login when I posted the 1st one  :P
So, I removed these maps from the maps menu. The only way to remove them is deleting the counter-strike.txt and day-of-defeat.txt from garrysmod/settings/mount ...
But now I don't have any CS:S sweps and maps, neither dod:source's ones.
It's like that now:
« Reply #5 on: June 02, 2007, 07:15:43 pm »
Gabriel, what spbogie is trying to say is that the maps menu is not, nor should be, affected by the 'ulx votemapAddmap' command.
If you look in your console after using the votemap command, -that- is where you should or shouldn't see maps you added (or if switched, shouldn't add)
The 'maps' command will show all available maps, whether they can be voted on or not.
Team Ulysses, I think we should make that controllable to though in some way, either following the same votemap list, or another implimentation.
Offline OvLoV
« Reply #6 on: June 03, 2007, 10:29:49 am »
I see that I'm not the only one who's having trouble with the server.ini file
Mine isn't loaded at all (at least thats what i think)
I have the same "maps out of boundery"
Nothing seems to be available from the server.ini file.
Maybe we can translate the tread to trouble with the server.ini file?
I realy could use some help.... :'(
Offline atomicspark
« Reply #7 on: June 03, 2007, 11:21:14 am »
As far as I know, the server.ini should be loaded. Unless of course there are problems with your install. I know all the advert commands work. I haven't tested the reserved slots yet. It's just the "excluding maps from votemap command" that I haven't been able to get to work.
Offline OvLoV
« Reply #8 on: June 03, 2007, 12:10:04 pm »
Oh well mine is at:
c:\steam\steamapps\username\garrysmod\garrysmod\addons\ulx\lua\ulx\configs\server.ini
I guess where it is suppose to be :-\
« Reply #9 on: June 03, 2007, 01:33:27 pm »
ULX throws an error if it can't find server.ini, so rest assured it DOES find it. ;)
