Author Topic: ULX Client Derma Theme  (Read 7784 times)
Offline nobbyblue
« on: January 20, 2016, 03:51:05 am »
Hello, I'd like to know where I can find the associated files with the Settings > Client > Derma Theme. The reason for this is because I actually clicked it and changed mine just to see what was available and upon doing so it seems to have completely broken my ULX.
In short I'd like to delete whatever is saying I'm using the theme I selected so it just goes back to the default.
The errors I receive in console are similar to this post:  /index.php/topic,8330.0.html#msg42359 />
Although I'm not at my main computer at the moment so I can't post the exact errors but they are more or less the same.
Upon leaving and rejoining my server I noticed that I can't actually access my ULX menu at all now, when attempting to access it I basically get the gui pop up but it is entirely empty with no options and blank tabs.
Thanks to anybody that can help me.
Offline nobbyblue
Re: ULX Client Derma Theme
« Reply #1 on: January 20, 2016, 12:19:27 pm »
After enough fiddling I managed to fix this issue on my own. For anybody else having this issue or a similar one do the following to completely remove whatever custom theme you may have clicked:
Steam > SteamApps > common > GarrysMod > garrysmod > data
Now simply delete your ULX and ULIB folders here and it will get rid of any client side settings you may have such as a Derma Theme.
« Reply #2 on: January 21, 2016, 08:07:34 am »
Yes, this is a recurring issue with Derma themes and the XGUI theme selector. I haven't been able to look into available themes and see what's triggering the errors.
But yes, if you do happen to get stuck with a bad theme, you just need to modify your CLIENT data/ulx/xgui.txt file- either delete it entirely or find the "skin" line and replace the value with "Default".
