Author Topic: ULX Motd  (Read 6496 times)
Offline Dave the Wizard Grandpa
ULX Motd
« on: February 05, 2016, 01:49:02 pm »
Okay so I am having trouble with the motd. I can't open it even though I have it set to showMotd 1. Please help! it says: The MOTD file could not be found, when I try to open it with the menu or type !motd
Re: ULX Motd
« Reply #1 on: February 05, 2016, 01:55:58 pm »
Did you create a local MOTD? If not, let me suggest using the MOTD generator instead.
Re: ULX Motd
« Reply #2 on: February 08, 2016, 09:02:40 am »
Additionally, make sure that you have "ulx_motdfile" cvar set to the correct parameter. The default should be 'ulx_motd.txt', and that should match the ulx_motd.txt file in the root directory of your Garry's Mod server.
*Fixed typo.
« Last Edit: February 08, 2016, 05:26:06 pm by Stickly Man! »
Offline roastchicken
  • I write code
Re: ULX Motd
« Reply #3 on: February 08, 2016, 02:56:40 pm »
Additionally, make sure that you have "ulx_modfile" cvar set to the correct parameter. The default should be 'ulx_motd.txt', and that should match the ulx_motd.txt file in the root directory of your Garry's Mod server.
Is "ulx_modfile" a spelling error, or is the cvar for the motdfile missing a t for some reason?
Re: ULX Motd
« Reply #4 on: February 08, 2016, 03:33:09 pm »
It has the 't'.
