Author Topic: Utime - Ultimate Edition [Who needs other versions now?]  (Read 91093 times)
Offline Marz
Re: Utime - Ultimate Edition [Who needs other versions now?]
« Reply #30 on: August 29, 2016, 04:06:58 pm »
Yes I am. the full command I put is "rcon UploadUtime" I've also tried running it from the actual server console. and not the ingame console.
Are you adding the Rcon part when running it from the server console?
Offline TheHeroBilly
« Reply #31 on: August 29, 2016, 04:11:24 pm »
no, only from in game.
« Reply #32 on: August 29, 2016, 04:16:23 pm »
So I scoured the console looking for errors, I found this:
  1. [ERROR] addons/utimeultimate/lua/autorun/sv_utime.lua:5: attempt to index global 'UTime' (a nil value)
  2.   1. unknown - addons/utimeultimate/lua/autorun/sv_utime.lua:5
Fixed that issue. Did not fix the missing command issue.
« Last Edit: August 29, 2016, 04:19:15 pm by TheHeroBilly »
Offline Marz
« Reply #33 on: August 30, 2016, 06:10:51 am »
Wanna hit me up on Steam? www.steamcommunity.com/id/marzimain and I'll check it out with you when i wake up?
Offline roastchicken
  • I write code
« Reply #34 on: August 30, 2016, 11:38:55 am »
What did you do to "fix that issue"?
« Reply #35 on: August 31, 2016, 08:22:20 am »
I was still uploading files when I started the server, I just restarted it and it fixed it.
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
« Reply #36 on: August 31, 2016, 07:23:43 pm »
[ERROR] addons/utime-ultimate-master/lua/autorun/sv_utime.lua:26: attempt to call method 'Query' (a nil value)
  1. fn - addons/utime-ultimate-master/lua/autorun/sv_utime.lua:26
   2. unknown - addons/ulib-master/lua/ulib/shared/hook.lua:110
I've tried everything at 12am, I can't be stuffed trying to fix it. Just asking for a little help?
EDIT: I have tried mysqloo and tmysql. Nothing is working at this point.
That sounds to me like you're missing mysqloo, or at least the correct version of it.
Use this one: https://facepunch.com/showthread.php?t=1357773 and at the bottom of the original post, download the Windows DLL + libmysql (unless of course you're running on a linux machine). Then place the gmsv_mysqloo_win32.dll in server garrysmod/lua/bin (sometimes the folder does not exist, so you will have to make it). The libmysql goes in the same directory the srcds.exe (or w/e you use to launch your server) directory is located.
Offline Beast
    • My Gaming Community
« Reply #37 on: September 24, 2016, 12:09:59 pm »
Sorry I haven't pushed anything new to it.  I'd advise against using it for now since the mysqlite module is kinda weird.  I'll be putting in my own module once I get some free time.
« Reply #38 on: September 24, 2016, 06:59:00 pm »
<Clip>I'd advise against using it
<clip>once I get some free time.
Beast, want us to move it to release archives until you update it?
It will lock it, but we can move it back if you message any of us admins.
