Author Topic: ULX Motd on dedicated server not showing up  (Read 32115 times)
Offline TheSenDest
Re: ULX Motd on dedicated server not showing up
« Reply #15 on: February 16, 2016, 02:12:10 pm »
Would it be possible to show you a list of addons I have on my server instead of that?
« Reply #16 on: February 16, 2016, 02:18:17 pm »
It would but I would have no idea if one of them conflicts.
Offline TheSenDest
« Reply #17 on: February 16, 2016, 02:19:07 pm »
http://steamcommunity.com/sharedfiles/filedetails/?id=621207229
That is the collection link. Other than that, I have three vehicle addon SVNs.
Offline feldma
  • 5696 hours in Gmod and counting!
    • Mega-Strike Network
« Reply #18 on: February 16, 2016, 03:35:13 pm »
Try getting rid of the SUI Scoreboard...
It's three years old and does apparently connect to ULX / ULib.
Solving 50% of people's questions by searching it up on google.
Trying to think of a cool idea to code, so I can inspire myself to code. If you want something done, please message me!
Offline TheSenDest
« Reply #19 on: February 16, 2016, 05:49:04 pm »
That could be it. Thank you for looking through it.
Do any of you know an updated scoreboard that shows teams or is this the only one?
Offline feldma
« Reply #20 on: February 16, 2016, 09:38:00 pm »
What do you mean by "Show Teams"?
You mean a DarkRP job?
Offline TheSenDest
« Reply #21 on: February 16, 2016, 10:08:00 pm »
Like ULX teams that show people's rank. That SUI scoreboard did it.
Anyway, I removed my entire collection from my server and the problem persisted.
Here is a picture of the two commands in my config file: http://i.imgur.com/0CPLjsp.png
My only legacy addons I have are: TDMCars SVN, LWCars SVN, Talon733Cars SVN, Adv Dupe 2 SVN, and two photon car scripts that I made myself with NO ulx commands in them, obviously.
Offline feldma
« Reply #22 on: February 16, 2016, 11:26:14 pm »
Maybe try changing the "motdfile" to "ulx_motdfile".
Otherwise I don't really know.
« Reply #23 on: February 18, 2016, 08:26:29 am »
SUI scoreboard should be fine- I doubt it would cause any problems.
One thing you might try is making a backup of your config.txt, then deleting it. Once you restart your server, a new config.txt should be generated. Use XGUI to configure the MOTD stuff, and then see if it works.
If not, it's very likely that something is going wrong with the code that's supposed to show the MOTD on join. It could be caused by a high server load on join. If possible, I would try removing EVERY other addon besides ULX/ULib and test it on sandbox. If it STILL isn't working, then let us know- I'd be happy to hop on your server and take a look myself.
(Also, side note: how big is your ulx_motd.txt file?)
EDIT: Oh, I just noticed- you're editing your server.cfg file? ULX stores most configurations in your server's data\ulx\config.txt file. The server.cfg cvars may get loaded too early, then get overwritten by defaults when ULX loads. which might be causing your issues. Try removing any ulx-related configuration from there (along with resetting your config.txt as described above) and see if that helps.
« Last Edit: February 18, 2016, 08:30:54 am by Stickly Man! »
Offline TheSenDest
« Reply #24 on: February 18, 2016, 04:42:32 pm »
FileZilla says the file is "4,587" but I have no idea what size measurement that's in or whatever.
Offline feldma
« Reply #25 on: February 18, 2016, 05:26:12 pm »
FileZilla generally measures things in bytes.. so that will be 4mb (not big).
Offline roastchicken
  • I write code
« Reply #26 on: February 19, 2016, 12:43:38 pm »
Not sure if it really matters, but 4587 is 4.5 KILObytes. 0.004 MEGAbytes.
Although I believe FileZilla measures in kilobytes, and 4587 kilobytes is equal to ~4 megabytes.
Offline feldma
« Reply #27 on: February 19, 2016, 12:52:02 pm »
Woops, that's what I meant :/
Offline TheSenDest
« Reply #28 on: February 28, 2016, 07:00:09 pm »
I EXTREMELY apologize for not replying. I got hit with a lot of school work and needed to get it done.
So, what you're saying is deleting anything related to ULX in my server.cfg & delete the config.txt in my data folder, correct?
EDIT:
This didn't work. Deleted the motd.txt AND config.txt and re-added both. Still nothing. There isn't even an option anywhere in ULX for it to show up. Why?
« Last Edit: February 28, 2016, 07:47:33 pm by TheSenDest »
« Reply #29 on: February 29, 2016, 04:12:51 am »
There is an option for it in XGUI but it may look different from what you remember
