Author Topic: ULX Menu not showing and getting an error in console  (Read 10838 times)
Offline DarkRiser15
« on: February 15, 2016, 12:21:21 pm »
Hello I whenever I go to open my ulx admin menu I get this error and this is what I see
Screenshot:   http://steamcommunity.com/sharedfiles/filedetails/?id=624707983
Error:    [ERROR] lua/vgui/dpropertysheet.lua:100: attempt to index field 'Tab' (a nil value)
  1. UpdateColours - lua/vgui/dpropertysheet.lua:100
   2. ApplySchemeSettings - lua/vgui/dlabel.lua:78
    3. ApplySchemeSettings - lua/vgui/dpropertysheet.lua:121
     4. unknown - lua/vgui/dpropertysheet.lua:65
      5. InvalidateLayout - [C]:-1
       6. unknown - lua/vgui/dlabel.lua:121
Offline feldma
  • 5696 hours in Gmod and counting!
    • Mega-Strike Network
Re: ULX Menu not showing and getting an error in console
« Reply #1 on: February 15, 2016, 12:29:33 pm »
Reinstall ULX.
Seems corrupted to me.
Solving 50% of people's questions by searching it up on google.
Trying to think of a cool idea to code, so I can inspire myself to code. If you want something done, please message me!
« Reply #2 on: February 15, 2016, 02:37:18 pm »
Did you change the skin to an invalid Derma theme?
Offline DarkRiser15
« Reply #3 on: February 15, 2016, 02:50:47 pm »
Not sure but it was a theme. And I am only a community manager. I cant reinstall it. It is server.
« Reply #4 on: February 15, 2016, 04:37:02 pm »
If you can send me whatever Derma theme you had selected, that would be helpful.
For now, go to your CLIENT's garrysmod/data/ulx/xgui.txt file and change the "skin" line to "Default", or just remove the xgui_settings.txt file entirely and rejoin. That should fix your issue in the meantime.
« Last Edit: March 16, 2017, 02:05:09 pm by Stickly Man! »
Offline kem008
« Reply #5 on: July 07, 2016, 04:31:29 am »
Warning: vgui.Create failed to create the VGUI component (DCollapsibleCategory)
[ERROR] addons/ulx/lua/ulx/modules/cl/xlib.lua:243: attempt to index local 'pnl' (a nil value)
  1. makecat - addons/ulx/lua/ulx/modules/cl/xlib.lua:243
   2. refresh - addons/ulx/lua/ulx/xgui/commands.lua:310
    3. unknown - addons/ulx/lua/ulx/xgui/commands.lua:391
     4. include - [C]:-1
      5. fn - addons/ulx/lua/ulx/modules/cl/xgui_client.lua:142
       6. Call - addons/ulib/lua/ulib/shared/hook.lua:110
        7. fn - addons/ulib/lua/ulib/cl_init.lua:49
         8. unknown - addons/ulib/lua/ulib/shared/hook.lua:110
   2. unknown - addons/ulx/lua/ulx/xgui/settings/server.lua:177
    3. include - [C]:-1
     4. fn - addons/ulx/lua/ulx/modules/cl/xgui_client.lua:147
      5. Call - addons/ulib/lua/ulib/shared/hook.lua:110
       6. fn - addons/ulib/lua/ulib/cl_init.lua:49
        7. unknown - addons/ulib/lua/ulib/shared/hook.lua:110
Compact freed 897024 bytes
Error creating 'trigger_checkpoint' (Make sure the file is AddCSLuaFile'd and there aren't any errors!)
Redownloading all lightmaps
[ERROR] lua/includes/extensions/table.lua:50: bad argument #1 to 'pairs' (table expected, got nil)
  1. pairs - [C]:-1
   2. Empty - lua/includes/extensions/table.lua:50
    3. fn - addons/ulx/lua/ulx/modules/cl/xgui_client.lua:464
     4. func - addons/ulib/lua/ulib/client/cl_util.lua:22
      5. unknown - lua/includes/extensions/net.lua:32
  1. pairs - [C]:-1
  1. pairs - [C]:-1
  1. pairs - [C]:-1
XGUI queue error: addons/ulx/lua/ulx/modules/cl/xlib.lua:243: attempt to index local 'pnl' (a nil value)
  1. pairs - [C]:-1
  1. pairs - [C]:-1
  1. pairs - [C]:-1
  1. pairs - [C]:-1
I get this every sending client info and there is no file called xgui.txt only xgui_settings.txt. Anybody can help?
« Reply #6 on: July 07, 2016, 09:33:59 am »
Bit of a necro there, but I would assume Sticky just hastily wrote down xgui.txt.
Check xgui_settings.txt. I'll bet you it's there.
Offline kem008
« Reply #7 on: July 07, 2016, 11:59:37 am »
Sorry not working changed to Default but it was on Default and remove it also same error.
« Reply #8 on: July 08, 2016, 12:23:44 am »
(Not a necro, I referred to this thread in this recent issue: https://github.com/TeamUlysses/ulx/issues/60)
Since that didn't fix the issue, it sounds like your problem is being caused by a conflicting addon or gamemode. Could you temporarily remove all of your other addons besides ULX/ULib, and run it on Sandbox gamemode and see if XGUI starts working? If it does, then set your gamemode and add addons back one by one until you find one that causes the issue.
