Author Topic: ULX Jail with reasons (Im making it worse!)  (Read 5220 times)
Offline BobTheDuck
« on: February 18, 2016, 04:20:12 pm »
Ok so Unjail functions as jail and reasons wont work... Im attempting to make modification of this code but dont know where to start...
        ------------------------------ Jail ------------------------------
        local doJail
        local jailableArea
        function ulx.jail( calling_ply, target_plys, seconds, reason, should_unjail )
        local affected_plys = {}
        for i=1, #target_plys do
        local v = target_plys[ i ]
        if not should_unjail then
        if ulx.getExclusive( v, calling_ply ) then
        ULib.tsayError( calling_ply, ulx.getExclusive( v, calling_ply ), true )
        elseif not jailableArea( v:GetPos() ) then
        ULib.tsayError( calling_ply, v:Nick() .. " is not in an area where a jail can be placed!", true )
        doJail( v, seconds )
        table.insert( affected_plys, v )
        elseif v.jail then
        v.jail.unjail()
        v.jail = nil
        local str = "#A jailed #T (#s)"
        if seconds > 0 then
        str = str .. " for #i seconds. (#s)"
        ulx.fancyLogAdmin( calling_ply, str, affected_plys, seconds, reason )
        ulx.fancyLogAdmin( calling_ply, "#A unjailed #T", affected_plys )
        local jail = ulx.command( CATEGORY_NAME, "ulx jail", ulx.jail, "!jail" )
        jail:addParam{ type=ULib.cmds.PlayersArg }
        jail:addParam{ type=ULib.cmds.NumArg, min=0, default=0, hint="seconds, 0 is forever", ULib.cmds.round, ULib.cmds.optional }
        jail:addParam{ type=ULib.cmds.StringArg, hint="reason", ULib.cmds.optional, ULib.cmds.takeRestOfLine }
        jail:addParam{ type=ULib.cmds.BoolArg, invisible=true }
        jail:defaultAccess( ULib.ACCESS_ADMIN )
        jail:help( "Jails target(s)." )
        jail:setOpposite( "ulx unjail", {_, _, _, true}, "!unjail" )
Re: ULX Jail with reasons (Im making it worse!)
« Reply #1 on: February 18, 2016, 04:42:27 pm »
Define "don't work".
Does it do anything?
Do you get any Lua errors when attempting to run it?
Where did you drop this code? What folder, what file name?
Offline BobTheDuck
« Reply #2 on: February 19, 2016, 08:28:03 am »
Well for starters unjail now functions as jail... and the reason wont show up period...
« Reply #3 on: February 19, 2016, 03:12:07 pm »
Bob, you can't just insert a text field variable without heavily modifying the text parser below or the ulx command object being passed to it/
'should_unjail' expects true or false. If it's anything but boolean 'true', well, that makes it 'false' and jails target.
My bet is you're not encapsulating "reason" in a single variable, so the say command is passing multiple word vars.
In the example below, #4 is expected to be true or false 'should_unjail'
1 2 3 4 5 6 7
jail target reason words go here true
would still jail a person because word 4 is 'go' and not a boolean.
I don't have the say command in front of me, and you didn't post what you're now using, but that's my recollection.
« Reply #4 on: February 22, 2016, 03:37:44 pm »
Found this while searching for something else.
Amazing what our search box will find, right?
/index.php/topic,6598.0.html
