Author Topic: Creating a force MOTD command, however I need some help.  (Read 7748 times)
Offline feldma
  • 5696 hours in Gmod and counting!
    • Mega-Strike Network
« on: February 21, 2016, 04:49:11 pm »
I'm creating a "ForceMOTD" command, however I do not want players to be able to close it instantly.
I looked at the motdmenu.lua file (or whatever it's called), however I'm not sure if copying the file would work.
If I changed
local isUrl
local url
function ulx.showMotdMenu( steamid )
local window = vgui.Create( "DFrame" )
window:SetSize( ScrW()*0.9, ScrH()*0.9 )
window:SetSize( 640, 480 )
window:Center()
window:SetTitle( "ULX MOTD" )
window:SetVisible( true )
window:MakePopup()
local html = vgui.Create( "DHTML", window )
--html:SetAllowLua( true ) -- Too much of a security risk for us to enable. Feel free to uncomment if you know what you're doing.
local button = vgui.Create( "DButton", window )
button:SetText( "Close" )
button.DoClick = function() window:Close() end
button:SetSize( 100, 40 )
button:SetPos( (window:GetWide() - button:GetWide()) / 2, window:GetTall() - button:GetTall() - 10 )
html:SetSize( window:GetWide() - 20, window:GetTall() - button:GetTall() - 50 )
html:SetPos( 10, 30 )
if not isUrl then
html:SetHTML( ULib.fileRead( "data/ulx_motd.txt" ) or "" )
url = string.gsub( url, "%%curmap%%", game.GetMap() )
url = string.gsub( url, "%%steamid%%", steamid )
html:OpenURL( url )
to
local isUrl
local url
window:Center()
window:MakePopup()
        timer.Simple(60, function()
        end)
if not isUrl then
html:OpenURL( url )
Would that work?
I'm not talking about the function name, just wondering if the motd would actually appear + would the timer on the close button work.
Thanks. I would test but at school.
EDIT: Just realised, even if I called this, it would open on the calling player. How would I make it open on the target_ply?
« Last Edit: February 21, 2016, 04:57:45 pm by feldma »
Solving 50% of people's questions by searching it up on google.
Trying to think of a cool idea to code, so I can inspire myself to code. If you want something done, please message me!
Re: Creating a force MOTD command, however I need some help.
« Reply #1 on: February 21, 2016, 04:59:24 pm »
Couldn't you just...
RunConsoleCommand("ulx", "cexec", target_ply:Nick(), "ulx motd")?
Or, , bypass the command entirely and just use cexec?
Offline feldma
« Reply #2 on: February 21, 2016, 05:00:30 pm »
Or, <censor>, bypass the command entirely and just use cexec?
Yes, we have been using cexec, but I need a command that forces the MOTD and makes the player unable to close it for a minute.
« Reply #3 on: February 21, 2016, 05:03:26 pm »
Ah, I'm sorry, didn't see that part.
Still, though. There's a hack for making it not closable for a few seconds on one of these threads here. Why not just make that the default? Continue using cexec and save yourself the trouble?
« Reply #4 on: February 21, 2016, 06:00:37 pm »
Search this developers corner section of the forum for 'motd', or 'motd close'
I'm sure there has been discussion of someone wanting this before.
Offline feldma
« Reply #5 on: February 21, 2016, 07:55:01 pm »
Yes, I saw those threads.
The problem is I don't want the default one to be timed.
« Reply #6 on: February 21, 2016, 08:30:30 pm »
I'm not saying edit the default one.
I'm saying use one of the others as example of how to do it.
Read one of the other ones, rename the command object and any vars that would conflict, and then add the timer as shown in examples.
Offline feldma
« Reply #7 on: February 21, 2016, 11:09:35 pm »
Hmm, I'll give that a try.
Thanks for helping.
