Author Topic: Forced download not working?  (Read 15585 times)
Offline shanedude
« on: June 07, 2007, 07:59:56 am »
 :-\ Well, I put a song in the forced download part of that "server.txt" and other people don't download it at all when they join.
I run a listen server if that helps at all.
Heres the whole thing -
// You can also add forced downloads here. Make sure you put quotes around the path/filename, and take out the comment string '//'.
// Add as many as you want. You can also add these to your map- or game-specific files.
ulx addForcedDownload "sound/Aerodynamic.mp3"
ulx addForcedDownload "sound/OneMoreTime.mp3"
Any idea why it doesn't work?
Re: Forced download not working?
« Reply #1 on: June 07, 2007, 11:52:44 am »
If you're using sv_downloadurl, it's case-sensitive and needs to be on the web-server. (I'd try all lower case anyways)
Offline shanedude
« Reply #2 on: June 07, 2007, 01:50:46 pm »
What do you mean? Also, I'm not using sv_downloadurl do I need it? Because I turned it on and still people don't hear the music that I hear.
I also put the song names in all lowercase, if that is what you meant.
« Last Edit: June 07, 2007, 02:48:13 pm by shanedude »
« Reply #3 on: June 07, 2007, 02:04:53 pm »
Just because they download it doesn't mean they'll hear it. I don't believe ulx playsound plays mp3's either.
Offline shanedude
« Reply #4 on: June 07, 2007, 02:17:50 pm »
Hm, then what format does it play? Because .mp3's play for me, just other people can't hear it.
Thanks for the help by the way.
« Last Edit: June 07, 2007, 02:51:48 pm by shanedude »
« Reply #5 on: June 07, 2007, 02:57:46 pm »
Engine support for MP3 is iffy at best. Wav is what it supports really.
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
« Reply #6 on: June 07, 2007, 03:50:24 pm »
It plays mp3s fine, I can attest to that since its what my Ipod game addon uses. Wav files don't cut it for me, they require a specific sample rate and blah what else to even play.
Offline shanedude
« Reply #7 on: June 09, 2007, 07:04:02 pm »
Sorry if this is a bump.
Here is the error thing I get, It doesn't make them download it even though I put in the servers config file to download it.
Here it is. Tested on a mingebag.
Client "mingebag" connected (Their IP).
mingebag has joined the game
Timer Error: ULib/server/ucl.lua:601: attempt to index field '?' (a nil value)
^^^ That, is the error I get.
Also, I have converted the .mp3's into .wav's and they still don't hear it.
I'm off to bed, I'll check this forum tomorrow.
« Reply #8 on: June 09, 2007, 07:06:42 pm »
That error has nothing to do with forced download. You're putting these commands into server.ini in the ULX config right?
Also, put your server console dump from server start here.
Offline shanedude
« Reply #9 on: June 10, 2007, 07:24:44 am »
Mounting Apps From /settings/mount/*.txt
   Mounting App 240 (cstrike) - Ok!
   Mounting App 300 (dod) - No Permission!
   Mounting App 340 (lostcoast) - Ok!
   Mounting App 220 (hl2) - Ok!
   Mounting App 380 (episodic) - No Permission!
   Mounting App 320 (hl2mp) - Ok!
   Mounting App 280 (hl1) - No Permission!
   Mounting App 360 (hl1mp) - No Permission!
Done!
Not mounting addon/gamemode 'day-of-defeat', requires missing GCF file (300)
Parent cvar in server.dll not allowed (sk_apc_missile_damage)
Garry's Mod client.dll Build #0027 [May 17 2007 16:35:02]
maxplayers set to 1
Heap: 256.00 Mb
Parsed 23 text messages
Adding Font resource/fonts/akbar.ttf
Adding Font resource/fonts/coolvetica.ttf
Adding Font resource/fonts/csd.ttf
Render Targets.. Done!
Couldn't find custom font file 'resource/HL2EP2.ttf'
Couldn't find custom font file 'materials/vgui/fonts/buttons_32.vbf'
Garry's Mod server.dll Build #0027 [May 17 2007 16:35:01]
execing config.cfg
Can't use cheat cvar dsp_dist_max in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar dsp_dist_min in multiplayer, unless the server has sv_cheats set to 1.
1 CPU, Frequency: 2.0 Ghz,  Features: AuthenticAMD SSE SSE2 MMX 3DNow RDTSC CMOV FCMOV
GetAllManifestFiles:  Unable to load maplist.txt
execing valve.rc
execing autoexec.cfg
Starting Level gm_flatgrass (Gamemode Override '')
maxplayers set to 7
Unknown command "sbox_allownpcs"
Unknown command "sbox_maxprops"
Unknown command "sbox_maxragdolls"
Unknown command "sbox_maxnpcs"
Unknown command "sbox_maxballoons"
Unknown command "sbox_maxeffects"
Unknown command "sbox_maxdynamite"
Unknown command "sbox_maxlamps"
Unknown command "sbox_maxthrusters"
Unknown command "sbox_maxwheels"
Unknown command "sbox_godmode"
Unknown command "sbox_plpldamage"
Unknown command "sbox_playergod"
Unknown command "sbox_noclip"
Unknown command "sbox_maxhoverballs"
Unknown command "sbox_maxvehicles"
Unknown command "sbox_maxbuttons"
Unknown command "sbox_maxsents"
Unknown command "sbox_maxemitters"
Unknown command "sbox_maxspawners"
Unknown command "sbox_maxturrets"
Unknown command "contraptionary_intermission_time"
Unknown command "contraptionary_guess_time"
Unknown command "contraptionary_max_guesses"
execing game.cfg
Network: IP 192.168.2.130, mode MP, dedicated No, ports 27015 SV / 27005 CL
Spawn Server gm_flatgrass
Begin loading faces (loads materials)
End loading faces (loads materials)
Lua initialized (Lua 5.1)
ERROR! Module 'ulib' not found!
//  shared/concommand.lua    //
//  shared/sh_ucl.lua         //
[ULIB] Loading module: ulx_init.lua
//  util.lua                 //
//  fun.lua                  //
//  vote.lua                 //
//  toolmode.lua             //
//  slots.lua                //
1 active EHandles!
ScriptEnforce: gamemodes/sandbox/clientscripts.txt wasn't found. This gamemode is unprotected.
Unknown command "ulx"
execing ulx_aliases.cfg
execing skill_manifest.cfg
execing skill.cfg
Executing listen server config file
Section [Scenes]: 1096 resources total 17.54 KB, 0.84 % of limit (2.10 MB)
7 player server started
couldn't exec listenserver.cfg
Adding master server 72.165.61.190:27011
Adding master server 68.142.72.250:27011
Client "Shane" connected (127.0.0.1:27005).
Connected to 127.0.0.1:27015
Connection to Steam servers successful.
   VAC secure mode is activated.
[L] Sandbox
Map: gm_flatgrass
Players:  1 / 7
Build 3056
Server Number 1
Initializing renderer...
Precaching Spawn Icons... DONE!
--- Missing Vgui material vgui/entities/weapon_annabelle
--- Missing Vgui material vgui/entities/weapon_alyxgun
--- Missing Vgui material vgui/entities/weapon_citizenpackage
--- Missing Vgui material vgui/entities/weapon_citizensuitcase
Server is running Garry's Mod Version 27 - gamemode 'sandbox'
Waiting for String Tables..
Creating RT Texture 'GModToolgunScreen'..DONE!
[UCL] Access set.
This server is running ULib version 2.04.
Joining Game..
ULX version 3.10 loaded.
^^^ That's all of it.
Offline EscudoDenali
« Reply #10 on: June 19, 2007, 01:58:45 am »
Yeah, im experiencing a problem with Forcedownload also!
I put the minigun swep into my addons folder, and it looks like this "addons/minigun/lua...." and all the other folders in the minigun folder.
So, i dont want people to see errors, so at bottom of the server config, i write "ulx addForcedDownload "addons/minigun"
and it doesn't make them download it! Please tell me what im doing wrong
Thanks
"What I lack in skill, I make up for in stupidity." - EscudoDenali
Escudo's Non-Tolerance Server <--- FUN
« Reply #11 on: June 19, 2007, 03:00:16 am »
You can't specify a directory escudo, you have to specify a file.
« Reply #12 on: June 19, 2007, 02:31:20 pm »
So... that means if I wanted clients to download a swep so it isnt an error, I would have to make a separate Forcedownload for EVERY file in the swep, like all the materials and everything?
« Reply #13 on: June 19, 2007, 02:57:27 pm »
Yes. Considering there's only two files for each resource (the .mdl and the .vmt), that's not so bad. Adding the .mdl will automatically add all those other model-related files (.vtx, .dx*, etc).
« Reply #14 on: June 19, 2007, 03:44:39 pm »
Well, just curious, is there ANY WAY to make it so that it will force people to download entire directories?
