Author Topic: Ulx command running two ulx commands  (Read 5638 times)
Offline Desasterx3
« on: March 02, 2016, 11:41:11 pm »
Hey there,
 I would like to create an ULX command that runs 2 other ulx commands on a specified player.
 Okay so i got these two commands i want to use:
ulx tempadduser
 !givepoints
These are custom commands that can be found here:
Temporary Users
Pointshop Commands
 I would need 3 different versions of this with different times and point amounts. You could just create 3 templates and i can edit the times. The commands for these should be:
!paket1 target
 !paket2 target
 !paket3 target
Thanks for anyone taking their time.
Offline roastchicken
  • I write code
Re: Ulx command running two ulx commands
« Reply #1 on: March 03, 2016, 12:21:54 pm »
I swear I saw this exact post, also made by you, yesterday. No need to make two threads.
Never mind, I can't find another thread. Deja Vu.
Browsing both Facepunch and Ulysses Forums really messes with your mind. https://facepunch.com/showthread.php?t=1508347
Anyways, I'm a bit confused why you posted this here. The people in the Facepunch thread suggested that you either:
A) Just run the commands via console
B) Copy the commands' function to your file and run them
Both of these will achieve the same thing except option A will likely print (Console) did something. Unless that really bothers you I think A is a better option because there's really no point in copying the code when you can just call it with a command.
« Last Edit: March 03, 2016, 12:28:28 pm by roastchicken »
Offline Desasterx3
« Reply #2 on: March 03, 2016, 10:28:12 pm »
Thanks for the answer.
Offline Desasterx3
« Reply #3 on: March 04, 2016, 08:05:33 am »
I cant seem to figure it out... Can you try to make an example piece of code? Sorry for bothering...
  • I write code
« Reply #4 on: March 04, 2016, 12:45:37 pm »
Global.RunConsoleCommand
  1. --inside command's function
  2. RunConsoleCommand( "ulx", "command", "arg1", "arg2" )
