Author Topic: Changing map votelist at the end of round in prop hunt  (Read 12154 times)
Offline devxrai
« on: March 03, 2016, 09:58:52 pm »
My ULib/ULX versions (run "ulx version" in console): 3.70
ULib v..
ULX v..
Game mode(s) I am having this problem on: prophunt
<insert errors here>
my problem is when the prophunt game ends after 10 rounds a votemap list comes up that looks like the fretta map list or it is. and has maps labeled "de_nameofmap"
and i have looked all over the web and i have looked inside all the files to see where to remove maps from the list and i have also added them to the exclude maps from votemap list but after 10 rounds it still has those maps in the votemap menu and i dont want them there i have restarted the server after changing the files maps but nothing changes. Does anyone know how to change the maps here?
Offline Undercover Orange
Re: Changing map votelist at the end of round in prop hunt
« Reply #1 on: July 02, 2016, 12:30:52 am »
hi. this is the owner of another prop hunt server. im wondering if you still have this problem? if so i can help you. its fairly easy
~ Undercover Orange
Offline Buzzkill
    • The Hundred Acre Bloodbath
« Reply #2 on: July 03, 2016, 09:35:38 pm »
Sounds like you're mounting CS:S content.  Check your /cfg/mount.cfg file...  you'll see something like this..
"mountcfg"
"cstrike" /home/steam/content/css/cstrike
You can rem out  (//) the cstrike entry if you want.  However, it's entirely possible that you in fact >want< to mount CSS content to support various CSS props/models, etc that you're running that rely on CSS content.  If that's the case, then yes...  you'll need to edit the mapvote system you're using to expressly blacklist the maps you don't want available for vote.
If you are using a fretta-based prophunt, then the map list is built/handled in sv_gmchanger.lua.  You'd edit the following to have it ignore maps you didn't care about (ie, not add them to AllMaps if they match a specific set of strings or pattern).
local AllMaps = file.Find( "maps/*.bsp", "GAME" )
for key, map in pairs( AllMaps ) do
AllMaps[ key ] = string.gsub( map, ".bsp", "" )
« Reply #3 on: July 05, 2016, 12:56:25 am »
its a bit easier than that if hes saying what i think hes saying
~ Undercover Orange
