Author Topic: ULX Timed Shutdown  (Read 8594 times)
Offline atomicspark
ULX Timed Shutdown
« on: June 08, 2007, 02:18:52 pm »
Should have a timed shutdown command. Something like "ulx shutdown <minutes>". Access should only be superadmins (must have rcon) and it must require a minute input or give error "You didn't specify time".
I would say it should advertise the countdown every ten minutes, five minutes if under 10, one minutes if under 5, etc. But if you actually had a countdown clock somewhere on the screen, that would be really nifty. Nothing large and threatening, just something simple. The text could start green then switch to red when under a minute. I'll help with the look (at least give my input) if I could just get a coder. Gotta know where we can place the timer first before we can decide where would look the best. ;)
Offline Golden-Death
  • Honored Lua Scripter
    • BlueFire
Re: ULX Timed Shutdown
« Reply #1 on: June 08, 2007, 02:20:08 pm »
Think this was already made? I'm not sure. But if you give me the commands to stop the server, then I can do it.
« Reply #2 on: June 08, 2007, 02:51:48 pm »
It was made in previous versions of ULX and hasn't been re-implemented yet. Also, the command to shut down the server is "quit".
Offline atomicspark
« Reply #3 on: June 15, 2007, 01:29:21 pm »
I believe the command is "exit". At least that is what I've been using. :P
« Reply #4 on: June 15, 2007, 02:12:56 pm »
"quti" works too :)
Offline Bacon Man
« Reply #5 on: June 21, 2007, 05:05:14 pm »
"killserver" thats the one and it works!
