We often see this question, even though we've answered it several times.
First and foremost - none of the reasons you can't pick up cars, or any prop, are
directly due to ULX.
1) ULX, out of the box, has
nothing to do with props - we only control group access.
Second -
2) TDM doesn't follow group inheritance of ULX - meaning;
a) DON'T create groups higher than superadmin and expect TDM or mods based on it to work -
Background -
/index.php/topic,6291.0.htmlb) Research how TDM/your car mod controls groups -
Background -
/index.php/topic,8919.0.html#msg45556 />Also stated here - /index.php/topic,8853.0.html#msg45235 />
Third, if using DarkRP,
3) Disable FAdmin (we see Fadmin conflict many times with ULX inheritance, even though we've tried to work with Fptje to use CAMI so it wouldn't)
/index.php/topic,8853.0.html#msg45249 />DarkRP seems to expect you as a host to create a group named Owner. Again, see 2a background link.
And if the above doesn't help, it's still likely not us - troubleshoot by removing other addons that adjust physgun.
Any prop protection script is likely a good point to start.
/index.php/topic,9174.0.html#msg46921 />
Per all the above, though we assist in group control, we've nothing to do with the groups your car mod expects physgun access to have.
