Author Topic: Anyone know how to prevent this crashing?  (Read 6765 times)
Offline SoggyWontonz
« on: March 12, 2016, 07:06:12 pm »
So, my server will have moments where all NPCs/Props/etc will just disappear yet we can still see the shadows of them, they'll come back, and it'll flicker, then 90% of the server's players gmod's will crash/
Anyone know a fix?
Offline roastchicken
  • I write code
Re: Anyone know how to prevent this crashing?
« Reply #1 on: March 13, 2016, 06:28:44 am »
I'm no expert, but the first place to look would be your server's specs. If you're running a VPS then you should be able to find this quite easily. If you're on a Garry's Mod host, then you might have to submit a ticket asking for the specs.
Do you have a lot of NPCs and props? What is your max playercount? How many people are on the server when it usually crashes?
It could be completely unrelated to serverside lag, but I think that's the most likely culprit.
« Reply #2 on: March 13, 2016, 03:24:01 pm »
We use a lot of NPCs when it crashes, but sometimes we will have more than usual and it doesn't crash
  • I write code
« Reply #3 on: March 13, 2016, 05:38:13 pm »
How many NPCs? What are your server specs?
Offline blinkenn
« Reply #4 on: March 18, 2016, 04:41:45 pm »
Anyone know a fix?
https://facepunch.com/showthread.php?t=1508517
Try to lower the amount of entities you have being ran on the client, The crashes is the client having more entities than the engine can hold.
I would recommend getting iNPC(https://steamcommunity.com/sharedfiles/filedetails/?id=632126111) for lowering NPC entities, but it isn't a perm fix.
