I can do ! but not /
Topic: I can do ! but not / (Read 5204 times)
nano120
March 26, 2016, 09:39:53 am »
I am a superadmin on a server and can only do !hp (any other commands as well) and not /hp, which is now getting on my nerves.
Is there a way to fix this?
Megiddo
Ulysses Team Member
Project Lead
Re: I can do ! but not /
March 26, 2016, 09:58:12 am »
Fix what? '/hp' has never been a ULX command.
nano120
Reply #2 on:
March 26, 2016, 10:03:11 am »
I cant do any slash commands including /spectate and /jail. However, i can do them with !spectate and !jail
Megiddo
Ulysses Team Member
Project Lead
Reply #3 on:
March 26, 2016, 10:04:24 am »
We have never supported using '/' as the command prefix. You can change that in the source code for each command if you want to use a different prefix though.
nano120
Reply #4 on:
March 26, 2016, 10:06:46 am »
Ok. Thanks for your help, but i have one more question. It works on a different server, but not this one. Could there be a reason for that?
Megiddo
Ulysses Team Member
Project Lead
Reply #5 on:
March 26, 2016, 10:11:09 am »
The other server owner must have modified the files himself or is using some other modification.
nano120
Reply #6 on:
March 26, 2016, 10:18:32 am »
Ok thanks!
Caustic Soda-Senpai
Sr. Member
<Insert something clever here>
Reply #7 on:
March 27, 2016, 01:35:22 am »
Quote from: nano120 on March 26, 2016, 10:18:32 am
Ok thanks!
"/[command]" is a built in DarkRP Command Set.
i.e. /setjailpos, /setwarrant, /jail, etc..
