Author Topic: Superadmin acces stuffed up?  (Read 4850 times)
Offline Frosty
« on: March 28, 2016, 11:27:40 am »
ok, so I got my dedicated server working fine and all until I added a owner group, yes a cringe as it is I removed it and stayed as a superadmin with one problem I decided to remove all groups and redo them but upon doing so superadmins don't have access to clean-up commands for my darkrp server and not only that I cant see those commands as before when you go tab>playername>
and only has "set access" and "msg" when I click on set acces and name the group superadmin and inherit superadmin it also says no access
I then tried googling everything and even looking through the forums here and yet it bares no fruit...
I did find the ulx command for the console which is ulx addgroup superadmin, but it only comes out to be inherited by user rank
deleted ulib and ulx and reinstalled It then re-added my self to superadmin group but I still don't have access to those commands but I can manage groups and all that so can any help me at all?
ulx version - ULX v3.70
ulib version - Ulib v2.60
Re: Superadmin acces stuffed up?
« Reply #1 on: March 28, 2016, 11:36:01 am »
You'll probably want to perform a factory reset seeing as you were planning on redoing things anyway;. See the FAQ for help on doing so.
Offline Frosty
« Reply #2 on: March 29, 2016, 12:39:02 am »
so just completely reset the whole server and its files?
Offline Frosty
« Reply #3 on: March 29, 2016, 12:42:28 am »
and I say that because I already done that twice and yet it still has no access
factory resetting the ulib and ulx data folders didn't work for me
« Reply #4 on: March 29, 2016, 06:20:14 am »
Are you sure you're deleting the correct folders? You should be deleting:
<server directory>/data/ulx
<server directory>/data/ulib
Just have to make sure, sorry if you've done that already. If you've done this and it's not working, you may want to fully reinstall ULX/ULib. Which means completely deleting them (data, addons, etc), and reinstalling them.
You shouldn't have to reset everything about your server. Unless there's a conflict somewhere (which doesn't seem likely right now), there's no need.
« Reply #5 on: March 29, 2016, 06:44:32 pm »
You likely still have Fadmin enabled, an admin system that comes with DarkRP.
If you have truly reset all ULib and ULX data files and access, then added yourself back to superadmin as described in many of our FAQs, then Fadmin likely has you locked in some way, which, isn't a ULX issue.
