Author Topic: I need someone to troubleshoot  (Read 5941 times)
Offline Government Official
« on: April 10, 2016, 12:33:34 pm »
I am Learning LUA and How to Make Custom ULX Commands and stuff
and I tried to make my own !fmotd command but for some reason it wont work There is no errors its just nothing happens
function ulx.fmotd( calling_ply, target_plys )
do target_plys:ConCommand( "ulx motd" )
ulx.fancyLogAdmin( calling_ply, true, "#A Forced #T to look at the Motd!", target_ply )
local fmotd = ulx.command( CATEGORY_NAME, "fmotd", ulx.respawn, "!fmotd", false )
fmotd:addParam{ type=ULib.cmds.PlayerArg }
fmotd:defaultAccess( ULib.ACCESS_ADMIN )
fmotd:help( "Forces a Player to look at the Motd." )
If you know the fix please help me
EDIT - JamminR - edited code tags from <> to []
« Last Edit: April 10, 2016, 02:03:11 pm by JamminR »
Re: I need someone to troubleshoot
« Reply #1 on: April 10, 2016, 02:01:29 pm »
Trust me, you're getting errors.
Likely at server startup.
'do' is not a valid command by itself.
You have an extra "end", and from the looks of it, you've modified a while/do statement that "end" used to finish.
Unless there's more code you've not shown us, "CATEGORY_NAME" isn't defined.
You're also calling one of our commands (ulx.respawn) once you get the command working. You'll want to call ulx.fmotd.
Once you get those sported out, you may want to edit your variable names for simplicity.
In ULX, we use 'target_plys' as a table, plural, more than one, of players.
Though you've used the proper setup in the command object to only send a single player, (ULib.cmds.PlayerArg), it would be easier on you if you don't use a variable that looks plural unless you plan to change it later to accept plural.
« Last Edit: April 10, 2016, 02:09:20 pm by JamminR »
« Reply #2 on: April 11, 2016, 11:48:48 am »
CATEGORY_NAME is Defined
I forgot to change it from ulx.respawn to ulx.fmotd when I Copied and pasted it
I tried just doing
target_plys:ConCommand( "ulx motd")
But Nothing happened so I tried puting a Do there
When I was first testing this I was testing it on TTT at first and it was saying something about target_plys but i will change it to target_ply
I will check for a error closely once I restart it
Is the first or second error an extra?
Offline roastchicken
  • I write code
« Reply #3 on: April 11, 2016, 04:33:22 pm »
I'm not sure about others, but I don't understand exactly what you're having trouble with right now. I suggest you post the full error(s) so we can help you better.
« Reply #4 on: April 11, 2016, 04:50:11 pm »
I just checked and there is no errors showing up at Start
Ok well I got rid of Do and the extra end and changed it too target_ply
The Motd wont show up but the Log works fine
« Last Edit: April 11, 2016, 04:59:01 pm by Government Official »
« Reply #5 on: April 11, 2016, 07:29:07 pm »
The server, or the player this is running on, should get errors somewhere.
Either at server startup, or when the command is run.
I don't normally blatantly do this.
But here is what I think should work. Compare it to whatever code you've already got.
CATEGORY_NAME = "homemade stuff"
function ulx.fmotd( calling_ply, target_ply )
target_ply:ConCommand( "ulx motd" )
local fmotd = ulx.command( CATEGORY_NAME, "ulx fmotd", ulx.fmotd, "!fmotd", false )
That's untested, but should work as far as my memory goes.
I wasn't sure if you wanted it as a "ulx fmotd" or just "fmotd" from the command line.
I went ahead and made it ulx fmotd
« Reply #6 on: April 12, 2016, 05:01:59 am »
Thanks it works fine
« Reply #7 on: April 12, 2016, 03:24:32 pm »
Welcome.
But the question is, can you see, compared to your last try, where some changes were made that might have broken yours?
Learning from what you have presented is best method for most.
Just taking it and putting it into your own file without knowing why it worked doesn't teach.
« Reply #8 on: April 12, 2016, 06:04:52 pm »
Yea i checked with the one I tried to edit with the changes u Suggested and I didn't see a difference except for the ulx fmotd thing Ill compare to the one I showed u guys
