Author Topic: Errors when in jail  (Read 4185 times)
Offline DankNessProvides
Errors when in jail
« on: April 11, 2016, 05:31:25 am »
I am getting an error with getting the print name of the weapon when the player is either stripped or in jail on darkrp how would I go about getting it to actually check if the player is either stripped of weapons or is in jail.
  1.         if LocalPlayer():Alive() and LocalPlayer():GetActiveWeapon():GetPrintName() != nil then
  2.                 draw.SimpleText( LocalPlayer():GetActiveWeapon():GetPrintName(), "Trebuchet24", ScrW() / 2 + 690, ScrH() / 2 + 305, Color(255,255,255), TEXT_ALIGN_CENTER, TEXT_ALIGN_TOP)
  3.         end
This code stops the error but removes the weapon name:
  1.         if LocalPlayer():Alive() and LocalPlayer():GetActiveWeapon != nil then
  2.                 if LocalPlayer():GetActiveWeapon():GetPrintName() != nil then
  3.                         draw.SimpleText( LocalPlayer():GetActiveWeapon():GetPrintName(), "Trebuchet24", ScrW() / 2 + 690, ScrH() / 2 + 305, Color(255,255,255), TEXT_ALIGN_CENTER, TEXT_ALIGN_TOP)
  4.                 end
  5.         end
Offline Buzzkill
    • The Hundred Acre Bloodbath
Re: Errors when in jail
« Reply #1 on: April 11, 2016, 12:45:35 pm »
Using an unchecked function return value as the object for another function call is an anti-pattern.  You should be checking all of those to make sure they are valid. Additionally, not every weapon will have a Print Name defined, necessarily.  They should -- but not a guarantee.
if ( IsValid( LocalPlayer() ) ) then
if ( IsValid( LocalPlayer():GetActiveWeapon() ) ) then
draw.SimpleText( LocalPlayer():GetActiveWeapon():GetPrintName() or "NoPrintNameDefined", "Trebuchet24", ScrW() / 2 + 690, ScrH() / 2 + 305, Color(255,255,255), TEXT_ALIGN_CENTER, TEXT_ALIGN_TOP)
Well, when they don't have any active weapon, what do you expect GetActiveWeapon() to return?  :)
« Last Edit: April 11, 2016, 12:47:35 pm by Buzzkill »
« Reply #2 on: April 13, 2016, 12:15:29 pm »
What I want to know is what is the DarkRP variable or how do I check to see if the player is in arrested.
Offline Buzzkill
