Author Topic: VIP  (Read 5224 times)
Offline BlackDeft
VIP
« on: April 13, 2016, 11:46:02 am »
Hi i want to create a vip using ulx
but if i create a script with one i want to give him some more healt and speed i get this error :
[ERROR] lua/viptest.lua:2: attempt to call method 'IsUserGroup' (a nil value)
  1. fn - lua/viptest.lua:2
   2. unknown - addons/ulib_557962238/lua/ulib/shared/hook.lua:110
    3. Spawn - [C]:-1
     4. unknown - gamemodes/base/gamemode/player.lua:115
 my script at that moment look :
local function spawn( ply )
   if ( Player( 2 ):IsUserGroup( "VIP" ) ) then
      SetPlayerSpeed( ply , 300, 80 )
hook.Add( "PlayerSpawn", "some_unique_name", spawn )
can someone tell me whats wrong ?
Offline Buzzkill
    • The Hundred Acre Bloodbath
Re: VIP
« Reply #1 on: April 13, 2016, 01:31:35 pm »
Why Player(2)?  Should by ply, like the other two references to it in your script.
"some_unique_name"
You really should change that to something, um... unique.  :)
Re: VIP
« Reply #2 on: May 10, 2016, 06:14:33 pm »
--snipped error
--Snipped code
I know this is fairly old and the OP didn't post anything new, but I'm just putting this here for future reference if anyone needs.
Especially if you try to load it in a singleplayer game, this error is no surprise. If you have ( Player( 2 ):IsUserGroup it's going to find the usergroup of that person. If you're in singleplayer, there is no one with the ID of 2, so it becomes a nil value. All you'd need to do is ( Player( ply ) because your function has the variable ply.
If you change it to just
  1. local function spawn( ply )
  2.    if ( Player( ply ):IsUserGroup( "VIP" ) ) then
  3.     SetPlayerSpeed( ply , 300, 80 )
  4.    end
  5. end
  6. hook.Add( "PlayerSpawn", "some_unique_name", spawn )
It should work just fine :)
Offline dankpepe
Re: VIP
« Reply #3 on: May 13, 2016, 08:52:51 am »
Or you could just use UTeam, no need for lua.
Re: VIP
« Reply #4 on: May 13, 2016, 09:43:02 am »
UTeam doesn't work on every gamemode.
