Author Topic: Why are ULX command callbacks declared inside the ulx namespace?  (Read 3597 times)
Offline Timmy
  • Code monkey
I have been wondering why ULX command callbacks are declared inside the global ulx namespace.
I'm talking about declaring a callback like:
  1. function ulx.callback( calling_ply )
Instead of using a local function:
  1. local function callback( calling_ply )
- Is there a particular reason for declaring these callbacks globally?
- Should developers follow this convention when writing modules for ULX?
Re: Why are ULX command callbacks declared inside the ulx namespace?
« Reply #1 on: April 30, 2016, 09:58:40 am »
By making it non-local, it makes it easier to modify by third-parties, and you are able to call it manually if you need to. There's really no reason to not have it accessible in this manner. You only need to follow our style if you are contributing code to the Ulysses repository.
Offline Timmy
  • Code monkey
« Reply #2 on: April 30, 2016, 03:14:28 pm »
OK! Thank you for your answers. :)
