Author Topic: Help with custom ulx command  (Read 6034 times)
Offline dankpepe
« on: May 03, 2016, 06:09:59 pm »
Not sure if I'm supposed to post here but I'm having trouble creating a custom ulx command. I have it mostly laid out.
function ulx.rpname( calling_ply, target_ply, name )
    if name and name ~= "" then
        target_ply:ply:SetRPName(name)
        ulx.fancyLogAdmin( calling_ply, true, "#A renamed #T", target_ply )
      name = nil
local rpname = ulx.command( CATEGORY_NAME, "ulx rpname", ulx.rpname, "!rpname", true )
rpname:addParam{ type=ULib.cmds.PlayerArg }
rpname:defaultAccess( ULib.ACCESS_ADMIN )
rpname:help( "Renames a player" )
I'm assuming the problem is in this line: target_ply:ply:SetRPName(name)
I want it to change the rp name in darkrp, but I'm not sure how to do it. Thanks.
Re: Help with custom ulx command
« Reply #1 on: May 03, 2016, 06:32:20 pm »
Get rid of ply:
It should just be target_ply:SetRPName(name)
Also, it looks like you have an extra 'end'. Remove the end after name = nil
Also, you need to define your name parameter for the command.
Add this line before rpname:defaultAccess( ULib.ACCESS_ADMIN )
rpname:addParam{ type=ULib.cmds.StringArg, hint="Name to rename player to", ULib.cmds.takeRestOfLine }
« Last Edit: May 03, 2016, 06:34:53 pm by MrPresident »
Offline dankpepe
« Reply #2 on: May 03, 2016, 06:55:32 pm »
That helped the server recognize it as a command but I'm still getting errors. So far I have:
local CATEGORY_NAME = "Danker"
      name = nil
   ULib.queueFunctionCall( ULib.rpname, target_ply, name, calling_ply )
I keep getting an error in console that says:
attempt to call method "SetRPName (a nil value)
« Reply #3 on: May 03, 2016, 07:21:15 pm »
that means the command you're trying to run 'SetRPName' is not valid.
you need to figure out what function you need to run on the player to set their RP name.
Unfortunately, I can't help you there as I have -50% experience with RP.
Offline roastchicken
  • I write code
« Reply #4 on: May 03, 2016, 07:39:35 pm »
The 'S' in SetRPName should not be capitalized. Player:setRPName()
Offline dankpepe
« Reply #5 on: May 03, 2016, 07:56:28 pm »
omfg i love you so much
Offline dankpepe
« Reply #6 on: May 03, 2016, 08:00:29 pm »
Thank you both so much for your help. If anyone else is looking at this later and wanted the finished version here you go:
http://pastebin.com/SzBJ3qkc
    if name then
        target_ply:setRPName(name)
rpname:addParam{ type=ULib.cmds.StringArg, hint="Name to rename player to)", ULib.cmds.takeRestOfLine }
