Author Topic: Referencing ULX command from a separate hook  (Read 4846 times)
« on: May 09, 2016, 02:34:57 pm »
Hey guys, so I'm trying to make a script for a TTT server that I'm staff on, and what I want it to do is when I press "I" it will slap the target I'm looking at and then in the chat "Are you afk?", as a "check afk" script. What I have now is this (and I don't know if I'm doing this right, should it be in a hook or a function?):
hook.Add( "Tick", "CheckAFK", function()
   local ply = LocalPlayer()
   local trace = util.GetPlayerTrace( ply )
   local traceRes = util.TraceLine( trace )
      if traceRes.HitNonWorld then
      local target = traceRes.Entity
         if target:IsPlayer() then
            if ply:input.WasKeyPressed( I ) then
end)
I don't know if this is right or not, and if it is, how do I continue it?
(If you need any clarification, just ask  :) )
Re: Referencing ULX command from a separate hook
« Reply #1 on: May 09, 2016, 02:40:16 pm »
You don't need Lua for this.
Bind I "ulx slap @;say are you AFK?"
« Reply #2 on: May 09, 2016, 03:36:42 pm »
Oh... So the @ makes it the target player?
« Reply #3 on: May 09, 2016, 03:58:12 pm »
That is correct. :)
There are a couple modifiers you should know:
^ yourself
* everyone
@ your target
« Reply #4 on: May 09, 2016, 04:11:13 pm »
Ah I didn't know about @ thanks.  :)
