Author Topic: "Your Prop is ghosted for antispam"?  (Read 24002 times)
Offline Tyler13700
« on: May 14, 2016, 08:55:48 am »
It says my prop is ghosted due to anti spam, I have this on a private server i play with my friends, its super annoying that i have to grab then release 40% of my props (or depending on how big it is) if the creation is too big it will just remove 60% of it and make a tower of "Prop Deleted due to Spam" this prevents my from spawning my acf heli (1 prop too much) :(
Re: "Your Prop is ghosted for antispam"?
« Reply #1 on: May 14, 2016, 09:20:46 am »
This is in no way related to ULX. Moving to Off Topic.
Offline roastchicken
  • I write code
« Reply #2 on: May 14, 2016, 12:08:28 pm »
I'm assuming this is on DarkRP. Anti Prop Spam is part of Falco's Prop Protection, which is bundled with DarkRP by default.
« Reply #3 on: May 14, 2016, 12:24:56 pm »
You should research at the DarkRP wiki or forums how to set exceptions
Offline Tyler13700
« Reply #4 on: May 14, 2016, 04:12:41 pm »
ok i didnt know it was FPP
« Reply #5 on: May 15, 2016, 07:11:54 pm »
ULX is just an admin mod, and does not act on things like prop spawning and or game-mode related things like DarkRP jobs/limits. If any one is having issues on DarkRP please check out http://wiki.darkrp.com/index.php/Main_Page or http://forum.darkrp.com/
Offline The Asian Aimbot
  • Rise and shine, Mr. Freeman, rise... and shine...
    • Asian Domain GMod Sandbox Server
« Reply #6 on: May 21, 2016, 04:40:43 pm »
This may be ULX unrelated, but I can still help you. I'm assuming you are using Falco's Prop Protection, if you're set as a superadmin on your server, simply disable the Prop Protection in the respective tab. If you don't want to disable it completely, just play with the settings until you're fine with it.
:D
The Asian Toaster man who escaped the Great Martian Coup of '69, hid in Beijing for 9 months, and was cast away by the FSM. Flew away w/ GoombasTasteGood and hid in Addis Ababa after fleeing to Botswana, then to Canada.
http://www.downloadmorewam.com
