Author Topic: Is there a way to change usernames?  (Read 5024 times)
« on: May 14, 2016, 06:31:38 pm »
This is the username I used a long time ago when I made this account in the beginning, but I'd like to go under a different name. Is there a way I can change my name while still being the same account?
Re: Is there a way to change usernames?
« Reply #1 on: May 14, 2016, 08:14:51 pm »
We (admins) can change your display name for you if you wish (and it follows Ulysses decency rules).
Actual login can be changed, but, last time I did that, SMF made the person change password and I think, forgot some other info about them.
I recommend only asking we change  your display name, and you keep the same login name you've had.
What display do you want?
« Reply #2 on: May 14, 2016, 09:03:52 pm »
The name I like to use now is "iViscosity". If you could change that, that'd be really cool! ;D
« Reply #3 on: May 14, 2016, 10:29:26 pm »
Done
Like JamminR said though, you'll still use your old username to login to the forums. We only changed the display name.
