Author Topic: Not sure why ULib.tsayColor is not working.  (Read 8968 times)
Offline StaTiiKxKALEB
« on: May 15, 2016, 10:08:16 am »
Any idea why ULib.tsayColor() is not working?
function ulx.asay( calling_ply, message )
    local players = player.GetAll()
    for i=#players, 1, -1 do
        local v = players[ i ]
        if not ULib.ucl.query( v, seeasayAccess ) and v ~= calling_ply then -- Calling player always gets to see the echo
            table.remove( players, i )
    ULib.tsayColor( players, false, Color(255,0,0), "(ADMIN CHAT) ", Color(0, 111, 255), calling_ply:Nick(), Color(255,255,255), ": ", message )
local asay = ulx.command( CATEGORY_NAME, "ulx asay", ulx.asay, "@", true, true )
asay:addParam{ type=ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
asay:defaultAccess( ULib.ACCESS_ALL )
asay:help( "Send a message to currently connected staff memebers." )
Re: Not sure why ULib.tsayColor is not working.
« Reply #1 on: May 15, 2016, 10:16:52 am »
For future reference, please explain "not working". It's very hard to fix a problem you know nothing about. Post any and all relevant errors, both client and server, as well as expected vs actual behavior.
What I can tell you is that ULib.tsayColor(Player ply, boolean wait, ...) only takes one player as an argument, not a table of players.
« Last Edit: May 15, 2016, 10:19:24 am by Bytewave »
« Reply #2 on: May 15, 2016, 12:29:56 pm »
Also, why are you trying to make an asay command when there already is one for ULX? If you want to change it, you can just edit the code itself (which I don't really recommend).
« Reply #3 on: May 15, 2016, 08:03:53 pm »
I'm not making my own, it's an edited version of it. I want it to have set colors and for "(Staff Chat)" to be red, etc, what's in the tsayColor().
« Reply #4 on: May 15, 2016, 08:15:23 pm »
I see. What do you mean by "not working", though? What errors are you getting?
« Reply #5 on: May 15, 2016, 08:40:38 pm »
I'm not getting any messages after I use the command, I think it's because of what "Bytewave" said earlier about it not accepting a table.
Offline Buzzkill
    • The Hundred Acre Bloodbath
« Reply #6 on: May 15, 2016, 10:00:58 pm »
Yeah, it is.   Move the tsay into the loop and change the check from negative to positive for asay privs and you should be fine.  (ie, do a tsay for each asay listener)
« Reply #7 on: May 16, 2016, 05:18:15 am »
Whenever I try to do it, it just gives this error.
« Reply #8 on: May 16, 2016, 07:27:02 am »
Let's see your updated code that is getting you that error.
« Reply #9 on: May 16, 2016, 07:45:28 am »
I fixed it.
    for i=1, #players do
        if ULib.ucl.query( v, seeasayAccess ) or v == calling_ply then -- Calling player always gets to see the echo
            ULib.tsayColor( v, false, Color(255,0,0), "(ADMIN CHAT) ", Color(0, 111, 255), calling_ply:Nick(), Color(255,255,255), ": ", message )
« Last Edit: May 16, 2016, 07:51:42 am by StaTiiKxKALEB »
