Author Topic: Ulx unban| adduserID not saving  (Read 3803 times)
Offline ryanwe
« on: May 21, 2016, 02:19:24 am »
ULib v2.60d (02/18/16)
ULX v3.70d (03/21/16
Lua errors shown in console, if any: None
As title says, whenever i run ulx adduserid or unban (any command that runs on a players id that isnt online) it doesnt save/work. For example, lets say i was going to demote an admin (without xgui) and did it through ulx adduserid it would state in chat that they were set to that rank, but when they join it would have their old rank?.(Also happens with ulx unban)This has been happening for a while now and persisted through ulx updates is there any way to fix this? We are running linux
« Last Edit: May 21, 2016, 06:31:12 am by ryanwe »
Re: Ulx unban| adduserID not saving
« Reply #1 on: May 21, 2016, 04:48:33 am »
Your problem, as described, indicates that your file and folder permissions are not set correctly. Whatever Linux user is running the server needs to have full access to everything in the data folder, as well as modifying the banned_user.cfg file.
Offline ryanwe
« Reply #2 on: May 21, 2016, 06:30:56 am »
I have check all the permissions and Read, Write and execute are all ticked. The weird thing is this only started happening around i would say around two months ago ( i know this wont help you at all).
