Author Topic: Freeze all props  (Read 13883 times)
Offline Son_Of_Flynn
Freeze all props
« on: June 04, 2016, 08:03:22 am »
A simple small script to freeze every prop on your server.
Great way to reduce lag and prevent prop spammers.
To install simply drop the file into your addons folder.
Raw Code:
function ulx.freezeprops( calling_ply )
        local Ent = ents.FindByClass("prop_physics")
                for _,Ent in pairs(Ent) do
                        if Ent:IsValid() then
                                local phys = Ent:GetPhysicsObject()
                                phys:EnableMotion(false)
        ulx.fancyLogAdmin( calling_ply, "#A froze all props" )
local freezeprops = ulx.command( CATEGORY_NAME, "ulx freezeprops", ulx.freezeprops, "!freezeprops" )
freezeprops:defaultAccess( ULib.ACCESS_ADMIN )
freezeprops:help( "Freeze every prop on the server." )
Offline Raimondas Ivaska
Re: Freeze all props
« Reply #1 on: June 18, 2016, 03:32:19 am »
Commands ?
« Reply #2 on: June 18, 2016, 06:46:01 am »
If you'd taken the 10 seconds to look at the bit of code, EVEN if you have no idea how to code, you could have guessed with 80% or more accuracy the name of the command needed.
ulx freezeprops
That being said, this code won't work without adding it to another file that already exists.
There's an undeclared variable in the code for the ULX command setup.
