Author Topic: cant make myself an admin anymore, after i changed to noaccess.  (Read 5437 times)
Offline omar1231
Expected behavior
Tell us what should happen
if i type ulx adduser mynamae superadmin i should be admin but .assumption fail
Actual behavior
i typed, ulx adduser leoshiro superadmin, before i used to do that with no problem
but since i made myself ulx adduser leoshiro no access it has been buggy and dont want me to become admin, i tried re installing and everything i tried instead adding to workshop addon instead of manually extracting them i tried everything still, after i type ulx adduser every key i type it returns
Tell us what happens instead
Error(s) in server console, if any
[ERROR] Assumption fail!
unknown - [C]:-1
Error(s) in player's console, if any
you dont have access to that command, leoshiro, i tried both server console and gmod console
Version
Run "ulx version" in console and paste the result
] ulx version
ULib v2.61
ULX v3.71
note: i tried reseting to default factory settings, i tried deleting both files in lua, i changed assumption reset error to reset( assumption) so it stops the error, the error stopped showing [ERROR] Assumption fail! 1. unknown - [C]:-1, this one is now gone, but i still cant make myself an admin
Offline omar1231
Re: cant make myself an admin anymore, after i changed to noaccess.
« Reply #1 on: June 07, 2016, 01:18:57 pm »
I Found the problem it was becuase i deleted darkrp modification, now i can change myself to admin but im having other problem now, when i press Q theres no Q or any props and i get this error in console mode
Couldn't include file 'darkrp\gamemode\cl_init.lua' (File not found) (<nowhere>)
[Leoshiro|2|STEAM_0:1:126517540] Lua Error:
Couldn't Load Init Script: 'darkrp/gamemode/cl_init.lua'
Offline davidk911
« Reply #2 on: June 07, 2016, 02:43:59 pm »
For any1 else having this issue, i dont know what this guy did but a much simpler way if u have access to the console is to type ulx adduser name rank, or if u have rcon password rcon_password "rconpassword" without quotes then rcon ulx adduser name rank.
Offline omar1231
« Reply #3 on: June 07, 2016, 02:51:53 pm »
i did that before it didnt work till i installed darkrpmodification now when i remove darkrpmodification ulx adduser or rcon address then password then rcon ulx adduser name rank, didnt work
Offline davidk911
« Reply #4 on: June 08, 2016, 03:35:01 am »
Why did you delete darkrpmodification?, your best bet is not to screw around with stuff unless you 100% understand what it does. and/or have a backup
« Reply #5 on: June 08, 2016, 03:58:23 am »
darkromodification is the folder for darkrp where you can change certain things in the game. You should always have it downloaded. Editing core files of a game mode especially is not a good idea. It could lead to errors and also makes it a pain in the ass to update as it rewrites all edits.
