Author Topic: Standard Source SDK commands blocked?  (Read 4389 times)
Offline olie304
« on: June 07, 2016, 01:38:48 pm »
Hi, I really like to play around with the source SDK commands that require sv_cheats, the servers I have all have sv_cheats at 1 and I have tested the commands/scripts in single player to make sure they work with gmod. I have come to the conclusion that for some reason ULX blocks the use of the !self flag and commands such as ent_fire !picker radius 20 and I also noticed it has blocked the ignite command. If there is a way to fix this I would be really thankful.
- Olie
Re: Standard Source SDK commands blocked?
« Reply #1 on: June 07, 2016, 02:51:19 pm »
I don't believe ULX blocks those things. You can try without ULX to confirm this if you wish.
