General
Developers Corner
Set Opposite
Topic: Set Opposite (Read 4206 times)
dankpepe
Jr. Member
Set Opposite
June 07, 2016, 07:41:57 pm »
Sorry about making 2 posts so close to each other, but I just ran into a problem. I can't run the opposite command. It was working until I modified the code to use PData. I get no errors, when I try to run the opposite I get:
"Usage: ulx uncover {Name to change} - Makes you go undercover (say: !undercover) (opposite: ulx uncover)"
here is my code:
shitty code
Last Edit: June 08, 2016, 07:54:48 pm by dankpepe
iViscosity
Respected Community Member
Re: Set Opposite
June 08, 2016, 07:28:04 am »
Ok I'm not super amazing with setOpposite, but try only one _ in it. If not, I really don't know lol I'm not good at it.
dankpepe
Jr. Member
Re: Set Opposite
Reply #2 on:
June 08, 2016, 07:30:19 am »
Ill try that, but it's weird because it was working before and all I did was change the body of the code
dankpepe
Jr. Member
Re: Set Opposite
Reply #3 on:
June 08, 2016, 12:47:37 pm »
Yeah that didn't work, that tried to set a string as a bool. Idk how i fixed it, but i did.
Last Edit: June 08, 2016, 08:07:31 pm by dankpepe
General
Developers Corner
Set Opposite
