General
Developers Corner
Damagelogs with console command
Topic: Damagelogs with console command (Read 4933 times)
iViscosity
Respected Community Member
June 12, 2016, 01:24:24 pm »
I was wondering if there was a way to open up the Damagelogs with a console command instead of the F8 key. A staff on my server has a broken F8 key but I don't want to change it for everyone (especially because I'm so used to F8), so is there a console command for the TTT Damagelogs (Not ttt_print_damagelogs, but the addon)
EDIT: Nevermind, just changed a little bit of code and fixed it.
if
input
IsKeyDown
self
Key
or
input
IsKeyDown
KEY_F7
and
not
self
pressed_key
then
Last Edit: June 12, 2016, 01:29:15 pm by iViscosity
roastchicken
Sr. Member
I write code
Re: Damagelogs with console command
June 12, 2016, 01:58:29 pm »
A much easier way to change this and a way that will allow you to update the damagelogs without having to copy this change over would be to simply edit the config, where there is a value for which key should open the damagelogs.
https://github.com/Tommy228/TTTDamagelogs/blob/6fc3ab624ed4e2590f82427159b16cb071f33a0e/lua/damagelogs/config/config.lua#L24
iViscosity
Reply #2 on:
June 12, 2016, 01:59:47 pm »
I know, but like I said, I wanted to keep it as F8 as thats what I'm used to and other staff are used to so I wanted another option.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #3 on:
June 12, 2016, 02:05:52 pm »
Searching the developers corner or releases section of the forum for damage logs should also find code for controlling damage log access with groups and perhaps the command needed. I didn't search, only remember it being discussed before.
iViscosity
Reply #4 on:
June 12, 2016, 02:07:32 pm »
No, I think you guys misunderstand what I was asking, I was trying to find ANOTHER way to access the damage logs,
as well as
F8 but I found it.
roastchicken
Sr. Member
I write code
Reply #5 on:
June 13, 2016, 01:02:47 am »
Ah, ok. I thought you were changing the key. My bad.
General
Developers Corner
