Author Topic: ulx thirdperson help  (Read 7672 times)
Offline C.Finley
« on: June 15, 2016, 10:54:53 am »
Its in the uncategorized category how to fix that and put it in a category.
if ( CLIENT ) then
local on = false -- default off
local function toggle()
on = !on
if on == true then
print( 'enabled' )
LocalPlayer():PrintMessage( HUD_PRINTTALK, "Third person mode enabled." )
print( 'disabled')
LocalPlayer():PrintMessage( HUD_PRINTTALK, "Third person mode disabled." )
hook.Add( "ShouldDrawLocalPlayer", "ThirdPersonDrawPlayer", function()
if on and LocalPlayer():Alive() then
return true
end )
hook.Add( "CalcView", "ThirdPersonView", function( ply, pos, angles, fov )
if on and ply:Alive() then
local view = {}
view.origin = pos - ( angles:Forward() * 70 ) + ( angles:Right() * 20 ) + ( angles:Up() * 5 )
--view.origin = pos - ( angles:Forward() * 70 )
view.angles = ply:EyeAngles() + Angle( 1, 1, 0 )
view.fov = fov
return GAMEMODE:CalcView( ply, view.origin, view.angles, view.fov )
end )
concommand.Add( "thirdperson_toggle", toggle )
if ( SERVER ) then
function ulx.thirdperson( calling_ply )
calling_ply:SendLua([[RunConsoleCommand("thirdperson_toggle")]])
local thirdperson = ulx.command( "Utility", "ulx thirdperson", ulx.thirdperson, {"!thirdperson", "!3p"}, true )
thirdperson:defaultAccess( ULib.ACCESS_ALL )
thirdperson:help( "Toggles third person mode" )
end -- end serverside
Offline OpticPotatOS
  • GLaDOS
    • Gaming for Everyone
Re: ulx thirdperson help
« Reply #1 on: June 15, 2016, 01:35:02 pm »
I'm not sure if you can, but if you can, you need to stick a category name at the top and in the ulx.command variable
My website isn't my website, rather, it's the gaming network my sever is connected to.
ttt.gfe.nu
Unforeseen Consequences
Offline C.Finley
« Reply #2 on: June 15, 2016, 01:41:31 pm »
i added a local category name and then changed the "Utility" to CATEGORY_NAME and still didnt work can u tell me which part maybe i did it wrong cause it still didnt work. Or I'm confused.
« Reply #3 on: June 15, 2016, 02:17:57 pm »
You don't; this is merely stylistic.
@C.Finley - You shouldn't be defining and registering your command on the server only. ULX commands should be registered on both the client and the server.
Offline C.Finley
« Reply #4 on: June 15, 2016, 02:24:55 pm »
All I wanna do is have that ulx thirdperson within a group category instead of uncategorized can you tell me how to do that? bytewave? or can I not ?
« Reply #5 on: June 15, 2016, 02:34:26 pm »
Again, don't register your command on the server only. That would be my best guess.
Offline C.Finley
« Reply #6 on: June 15, 2016, 02:34:56 pm »
im sorry but I am a noob and have no understand what that means. "don't register your command on the server only."
« Last Edit: June 15, 2016, 02:37:34 pm by C.Finley »
« Reply #7 on: June 15, 2016, 02:37:27 pm »
  1. if ( SERVER ) then
  2. end -- end serverside
Remove these two lines. Simple.
Offline C.Finley
« Reply #8 on: June 15, 2016, 02:49:40 pm »
Thank You.
