Author Topic: Ignore PlayerSay  (Read 7170 times)
Offline dankpepe
Ignore PlayerSay
« on: June 18, 2016, 11:15:02 pm »
How does ulx ignore the PlayerSay hook for commands? For example, why can people still type in admin chat while muted?
Re: Ignore PlayerSay
« Reply #1 on: June 19, 2016, 07:15:04 am »
Either hook priority, or they're using the ulx * console commands as opposed to their chat counterparts.
« Reply #2 on: June 19, 2016, 08:49:31 am »
Additionally, admin chat isn't standard chat. I'd have to dig into our code, but it's likely that once @ is used, it would never get to the playersay hook anyway.
Essentially, we never return chat text in the first place.
« Reply #3 on: June 19, 2016, 09:31:41 am »
What JamminR said, ulx asay uses no hooks, as a matter of fact, and sends a message to only those allowed to see it and the person who used it. Can't remember if they used fancyLog or fancyLogAdmin, though.
Offline dankpepe
« Reply #4 on: June 19, 2016, 09:55:48 am »
That makes sense. Do you know how ulx detects if you type something without using the PlayerSay hook?
« Reply #5 on: June 19, 2016, 09:56:51 am »
It's all in the code. It doesn't detect hooks or skip them or anything, it simply doesn't use them.
Offline dankpepe
« Reply #6 on: June 19, 2016, 10:12:37 am »
How does ulx know to execute a command when someone types a command in chat without using hooks?
« Reply #7 on: June 19, 2016, 10:27:52 am »
It's in the command. When you define a ulx.command at the bottom of the code, you can assign a command line which, when you use in the chat, it will execute that command.
« Reply #8 on: June 19, 2016, 11:05:23 am »
You're misinterpreting things.
ulx.command registers a new command, telling UL(x|ib) that you want x to happen when y is said or z is run in the console. HOWEVER, this does not mean hooks aren't used internally. They are, in fact, used.
This hook is registered with HOOK_HIGH priority. The hook responsible for gimps and mutes is registered with HOOK_LOW priority. Therefore, the PlayerSay hook that checks for commands takes the highest precedence (if I understand ULib's improved hook system correctly).
« Reply #9 on: June 19, 2016, 11:07:03 am »
Ah, what I was thinking was you don't need to specifically specify a hook when making the command.
« Reply #10 on: June 19, 2016, 02:02:57 pm »
Yes, you understand it correctly Bytewave. We didn't want admins panicking if they muted/gimped themselves and then couldn't run the commands they were used to (from chat).
