server IP 192.95.39.227:27015
https://www.gametracker.com/server_info/192.95.39.227:27015my server is always up unless something happens and it crashes but it should automatically come back on.
there are 25 slots with one reserved slot for myself.
Now has a teamspeak 3 server!IP Below ca22.ts3.cloud:1386
The Undercover Gaming Prop Hunt server very unique. the gravity is set to 270 allowing props to get into better places. we also have a double jump so they can get in even better spots along with making juking a lot more fun as you can change directions when you jump the second time. we also have a point shop and will be accepting player model requests for a small donation of $2 USD. just tell an admin or myself that you have donated and you will get your playermodel within the next 2 map changes
more details:
It contains Prop Hunt v2 which allows:
- Prop rotation
- Prop lock
- Smooth movement
It contains a point shop that adds in the following:
- Better quality re-skin of the point shop
- Player models
- Point shop extras
- Adding playermodels instantly!
It has a great custom loading screen with music
adjusted low enough for people to talk over and listen to at the same timeContains/Will contain FastDL
Contains a bunch of PH maps..
There's much more, listed are only the most important details, so if you guys like what you see, go ahead and join the server, it's also still in development so things may be added & or removed in the future.
It's running off of donations, so if you guys like what you see, become a Donator today!I can confirm that this is one of the best Prop Hunt servers around.
Pretty much beats all of the other Prop Hunt servers.
*GameTracker banner added*
