Author Topic: I would like something done that is semi complicated.  (Read 5832 times)
Offline Undercover Orange
« on: July 27, 2016, 10:21:31 pm »
in every single game mode on Garrys Mod a name pops up when you look at a player. i would like a way to disable this so name will not pop up.
~ Undercover Orange
Re: I would like something done that is semi complicated.
« Reply #1 on: July 28, 2016, 12:23:16 am »
Ethorbit, I think he was more than clear enough with his request..
undercoverorange, it's not difficult at all.
add the following code to a file and place that file in:
garrysmod/lua/autorun/client
  1. AddCSLuaFile()
  2.
  3. function GM:HUDDrawTargetID()
  4.      return false
  5. end
  6.
or simply insert the following code into your gamemode's cl_init.lua file:
  1. function GM:HUDDrawTargetID()
  2.      return false
  3. end
  4.
« Reply #2 on: July 28, 2016, 07:48:46 am »
  2.      return false
  3. end
  4.
do I need to add a number inside the brackets? also any specific place i need to put that? (server is prop hunt if that helps any)
I though it would be way more complicated than that. I'm slowly learning lua by just reading my server files on my free time.
« Last Edit: July 28, 2016, 07:54:30 am by undercoverorange »
~ Undercover Orange
« Reply #3 on: July 28, 2016, 10:24:21 am »
I told you where to place it in the first post.
And no.. no numbers.. just copy and paste what I have there for you.
« Reply #4 on: July 28, 2016, 10:53:33 am »
what I meant was like do i need to put it in a specific place on that file?
~ Undercover Orange
« Reply #5 on: July 28, 2016, 06:34:30 pm »
No, just at the bottom would be fine.
« Reply #6 on: July 28, 2016, 07:41:00 pm »
k thanks
~ Undercover Orange
