Author Topic: ulib and ulx startup errors any got any ideas?  (Read 5047 times)
Offline davidk911
« on: July 28, 2016, 07:09:39 am »
Hi so im getting this error on start up of ulib and ulx any1 know why?
[ERROR] addons/ulib/lua/ulib/shared/hook.lua:110: RunString:693: bad argument #1
 to 'lower' (string expected, got table)
  1. fn - [C]:-1
   2. unknown - addons/ulib/lua/ulib/shared/hook.lua:110
[ERROR] addons/ulib/lua/ulib/shared/hook.lua:110: RunString:475: attempt to inde
x field 'data' (a nil value)
  1. fn - [C]:-1
Re: ulib and ulx startup errors any got any ideas?
« Reply #1 on: July 28, 2016, 10:31:27 am »
RunString is something people use to inject code.
You might have an addon installed that is trying to inject code and its failing.
This could be a problem for you.
Injected code is how some malicious coders open backdoors to your server.
It could also be DRM or something that an addon uses. It's hard to say.
« Reply #2 on: July 28, 2016, 02:05:13 pm »
You would receive this error without ULX/ULib installed. Unfortunately, there are no clues as to what's causing the error. I'd recommend removing all addons and adding them back in one by one to check what's causing it.
As Mr. P. suggested, it may be malicious as well. But once you remove all addons and no longer get that error, you'll know it is likely no longer trying to inject code.
Offline Undercover Orange
« Reply #3 on: July 28, 2016, 07:39:56 pm »
Good thing I read everything that gets posted. I was getting this too and found out it was coming from one of my player models
~ Undercover Orange
« Reply #4 on: July 28, 2016, 11:32:47 pm »
There is NO reason a player model addon should be injecting code. This is almost certainly malicious.
« Reply #5 on: July 29, 2016, 12:27:17 am »
which is why i removed it.
~ Undercover Orange
Offline davidk911
« Reply #6 on: July 29, 2016, 03:08:51 am »
Thanks for responses not got time atm but i'll go through all my addons tonight thanks for the info again
« Reply #7 on: July 29, 2016, 07:56:09 pm »
Either of you, please educate us on which was removed.
This would be very helpful to the rest of the community.
« Reply #8 on: July 30, 2016, 02:35:38 pm »
JamminR. i had reported the addon to steam and they have taken it down. id tell you the author but i dont remember who it was (also why is my karma going down im trying my best to help people :P)
~ Undercover Orange
