Author Topic: Trial Mods and Moderators considered as admins???  (Read 12292 times)
Offline Vaga Bond
« on: August 01, 2016, 01:49:27 pm »
ULib v2.61d (06/12/16)
ULX v3.71d (07/02/16)
<insert errors here>
So what my real issue here is the fact that Moderators and Trial Mods are able to spawn in weapons and entities when I set the settings in settings.lua to admin only for both. I don't understand why, but they're being considered admins (ran a simple line on an expression 2 code to figure that out). How do I set it to so they're not considered admins?
Re: Trial Mods and Moderators considered as admins???
« Reply #1 on: August 01, 2016, 02:07:16 pm »
How is your inheritance tree set up? If moderators inherit from admin, they will be considered admin by IsAdmin().
Offline .gdraw
    • Steam
« Reply #2 on: August 01, 2016, 02:46:01 pm »
Making them inherit from user (or whatever you'd like, just not admin) and they shouldn't be considered an admin.
Offline Vaga Bond
« Reply #3 on: August 07, 2016, 08:22:25 am »
superadmin
Co-Owner
Superadmin
Head-Admin
admin
Moderator
TrialMod
trusted
user
Ranks inherit from the one below each other (i.e. Head-Admin inherits admin, admin inherits Moderator, etc.)
They do inherit admin.
« Reply #4 on: August 07, 2016, 10:15:37 am »
superadmin
Co-Owner
Superadmin
Head-Admin
admin
Moderator
TrialMod
trusted
user
From your example description, you state one inherits the next below.
If your script is set for admin only, then the groups below admin in your list should NOT be able to spawn/do admin stuff.
However, you then state;
Which is it?? Does your inheritance tree look like your list top to bottom, or do Moderator and Trial-mod inherit admin.
If they inherit admin, that is why they can spawn.
If they do not inherit admin, it's possible you have an issue with Fadmin or another conflicting addon.
Have you disabled Fadmin?
While your server is running, with a Moderator or trial mod on, please run "ulx debuginfo" from your server console.
It will output a file and tell you where it did.
Attach that file (using the attachments and other options link) to your next post.
Offline .gdraw
    • Steam
« Reply #5 on: August 07, 2016, 03:16:44 pm »
-snip
Then make them not inherit Admin, and your problem is solved.
« Reply #6 on: August 09, 2016, 07:56:12 am »
The easiest way to detect if you have branches in your inheritance tree is to run this command on your SERVER console:
PrintTable( ULib.ucl.getInheritanceTree() )
Alternately, you could run this ulx command from your client:
ulx luarun =ULib.ucl.getInheritanceTree()
Paste the result here, and we can help you analyze it.
Offline Vaga Bond
« Reply #7 on: August 13, 2016, 10:04:53 am »
Sorry for the late reply(ies) I'm very busy going back and forth with things.
Result:
user:
   donator:
   trusted:
      trialmod:
         moderator:
            admin:
               superadmin:
                  Head-Admin:
                     Co-Owner:
                        owner:
   noaccess:
   veteran:
Exactly from console.
My mistake. I meant to say they do not inherit Admin.
« Reply #8 on: August 13, 2016, 01:05:01 pm »
Is your "trusted" group also able to spawn admin only things?
Offline Vaga Bond
« Reply #9 on: August 14, 2016, 09:48:18 am »
No.
« Reply #10 on: August 14, 2016, 12:45:46 pm »
The best I can figure is that you have another addon changing the definition of "IsAdmin". You could easily confirm this by running your server with only ULX and ULib (no other addons).
« Reply #11 on: August 14, 2016, 01:52:53 pm »
As you have DarkRP, I'd start with disabling FAdmin - it's been known to cause group conflicts with that you specify using ULX.
Offline Vaga Bond
« Reply #12 on: August 14, 2016, 04:13:51 pm »
What is the addon folder for FAdmin called? Or how would I disable it? I'm not too familiar with FAdmin and am not a big fan of it either.
Where can I find said addon?
« Reply #13 on: August 14, 2016, 07:36:46 pm »
See our FAQs.
/index.php/topic,5665.0.html
If that isn't clear or instructions have changed since we made that answer, you'll need to go to the DarkRP forums and wiki to find more answers
If disable of Fadmin doesn't help, you'll need to remove all addons but ulx and ULib, then add back one or two at a time and restart the server after each.
Once you've added back the offending addon, you'll know.
It's still possible you have can_target broken too.
Offline Vaga Bond
« Reply #14 on: August 21, 2016, 12:15:34 pm »
See our FAQs.
Sorry for the late reply.
I have disabled FAdmin and it fixed the targetting. Thanks for the help!
