Author Topic: Read players steamid from the ban list  (Read 5684 times)
Offline warhammer
« on: August 12, 2016, 11:30:22 am »
I want to create/put it in a lua file that reads the ban list and if it has a spercific steamid on the list it will unban it and perhaps run it on a timer to check every 5 seconds
i know i will need to read it by something like
local input = ULib.fileRead( "data/ulib/bans.txt" )
but im not sure where to go.
any help appreciated.
« Last Edit: August 12, 2016, 11:31:56 am by warhammer »
Re: Read players steamid from the ban list
« Reply #1 on: August 12, 2016, 11:33:14 am »
http://wiki.garrysmod.com/page/file/Read Check this out. I can't help too much at the moment but probably later.
« Reply #2 on: August 12, 2016, 12:10:38 pm »
That seems a bit malicious, but...
I pulled this snipped straight from ulib/server/player.lua. It's only a snippet, and would have to be used in the context of a function, but it checks if a SteamID is banned and, if it is, does nothing, otherwise it will continue with any lines following it.
  1. local banData = ULib.bans[ steamid ]
  2. if not banData then return end -- Not banned
Offline roastchicken
  • I write code
« Reply #3 on: August 12, 2016, 06:05:21 pm »
I cannot think of any use case for this that isn't malicious or at least misguided.
« Reply #4 on: August 12, 2016, 06:56:13 pm »
Keeping the owner of the server unbanned, maybe?
« Reply #5 on: August 12, 2016, 07:00:20 pm »
Actually, I was fine with the question, right up until the point 'run on a timer every 5 seconds'.
It then seems like a malicious injection attempt, like many exploits that fill a console with constant unban requests of the script kiddie.
Otherwise, I could see it becoming some custom integration with ULib (or ULX), but not using ULib/ulx (un)ban functions.
SQL mods perhaps.
  • I write code
« Reply #6 on: August 13, 2016, 04:46:50 am »
I would consider that misguided. You shouldn't rely on yourself being unbanned due to a Lua script. I also wonder why they couldn't just unban themselves via console.
Offline Caustic Soda-Senpai
    • Steam Page
« Reply #7 on: August 17, 2016, 07:05:36 pm »
My thoughts exactly.
