Author Topic: Utime Data  (Read 5860 times)
Offline Cucuy Gaming
Utime Data
« on: August 13, 2016, 12:05:10 am »
Where is the utime data file located in the files cause I want to see how much time someone has on the server that I haven't seen in a while. Please Help.
Re: Utime Data
« Reply #1 on: August 13, 2016, 01:19:27 am »
utime is stored in the sv.db file. It uses SQLite, not data files.
Offline roastchicken
  • I write code
Re: Utime Data
« Reply #2 on: August 13, 2016, 04:50:56 am »
As a word of caution from someone who has experienced data loss due to this: resist the temptation to open the SQLite database while the server is running. If you try to read the file and something tries to write to the database at the same time, you're at risk of corruption. Shut down the server, then open sv.db.
