Author Topic: Removing Users doesn't work  (Read 4158 times)
Offline Skeptic1
« on: August 13, 2016, 02:14:15 pm »
Hi, I am having this issue /index.php/topic,4186.0.html. But when I look in "users.txt" there is no one specified to be a certain rank at all, only Garry himself.
EDIT
FILL OUT THE FOLLOWING!
 If you still need help, fill in the following information.
ULib 3.71
ULX v.. 2.61
N/A
« Last Edit: August 20, 2016, 07:43:13 pm by Skeptic1 »
Re: Removing Users doesn't work
« Reply #1 on: August 13, 2016, 02:18:45 pm »
Are you looking in your servers users file, or client? Needs to be server.
Also, if you can run, from server console/rcon/srcds console, preferably while that player is connected, "ulx debuginfo", then paste the contents of that file here, we can look and see if they have access through normal ULX methods.
If they aren't connected when you run it, make sure you provide us the steamid and playername they're using.
Additionally, I've modified your post.
Don't just delete what we ask for.
Though we thank you for searching as the first sentence of our template asks you to do, the other information we ask for is helpful for research and tracking purposes.
« Last Edit: August 13, 2016, 02:21:34 pm by JamminR »
Offline Skeptic1
« Reply #2 on: August 20, 2016, 07:43:35 pm »
Yes, I am looking on the server files through FTP and the file still isn't there.
« Reply #3 on: August 20, 2016, 10:13:28 pm »
DarkRP - tried disabling Fadmin? It's known to conflict with groups, and is likely the issue if enabled.
If after disabling same issue exists after removing, please attach a debuginfo text file.
From server console/rcon/srcds console, preferably while that player is connected, "ulx debuginfo", then paste the contents of that file here, we can look and see if they have access through normal ULX methods.
