Author Topic: Superadmin rank can target Owner props  (Read 8766 times)
Offline DrCheesepuffs
« on: August 18, 2016, 05:03:03 pm »
For some reason, the superadmin rank on my server is able to target my props even though I am the Owner, how do I fix this?
Re: Superadmin rank can target Owner props
« Reply #1 on: August 18, 2016, 06:55:32 pm »
ULX
has
nothing
to
do
with
props.
If you're using another item such as UPS, you didn't give enough info.
« Reply #2 on: August 20, 2016, 06:16:03 am »
We don't have that UPS thing you are talking about. We have URM, not sure if that has anything to do with it. And I thought it was ULX because I assumed it had something to do with the groups. Also, what information do you need?
Offline Caustic Soda-Senpai
    • Steam Page
« Reply #3 on: August 20, 2016, 07:03:32 am »
We don't have that UPS thing you are talking about...what information do you need?
Contact the creator of URM. They'll be able to help you better than we can.
Offline The Asian Aimbot
  • Rise and shine, Mr. Freeman, rise... and shine...
    • Asian Domain GMod Sandbox Server
« Reply #4 on: August 20, 2016, 07:16:56 am »
Assuming you're using Simple Prop Protection or Falco's Prop Protection, admins can pick up all props, including other admin's props, regardless of power. I have no clue if there's a way around this, but you may want to try another plugin which allows you to restrict other admins from picking up a higher ranks props.
The Asian Toaster man who escaped the Great Martian Coup of '69, hid in Beijing for 9 months, and was cast away by the FSM. Flew away w/ GoombasTasteGood and hid in Addis Ababa after fleeing to Botswana, then to Canada.
http://www.downloadmorewam.com
« Reply #5 on: August 20, 2016, 08:18:34 am »
It very well may.
However, ULX has nothing to do with group access to props.
The only control I can think of we even touch on is being able to physgun other players.
You could be running without ULX, straight server, no admin mod, and have people in different groups using Gmod default /settings/users.txt file, and still likely have this issue (providing your prop system wasn't built on ULX, which we don't fully recommend. We recommend devs build on ULIb, not ULX.
« Reply #6 on: August 22, 2016, 04:34:32 pm »
I just realized my friend had superadmin as the rank name and dind't make it something else...
