Author Topic: Need help with "broken commands" URGENT  (Read 3638 times)
Offline SmallsGaming
« on: August 30, 2016, 01:45:55 am »
My ULib/ULX versions (run "ulx version" in console): My problem has to do with this.
ULib v..
ULX v..
Ok so i downloaded some custom files in the form of a zip to upload into my server because i needed stopsound cleardecals and ragdolls. So i put the zip into my addon folder and then extracted it. But then when i go into my server i can't do any commands at all. !menu !god !noclip nothing. The thread says some commands are broke due to it being an old script. Please help i really need the stopsound, cleardecals and clearragdolls to be added. The zip is below.
« Last Edit: August 30, 2016, 12:47:44 pm by SmallsGaming »
Re: Need help with "broken commands" URGENT
« Reply #1 on: August 30, 2016, 02:49:12 pm »
This isn't really a ULX issue.
Go into your server addons folder and delete the addon you unzipped.
If you unzipped both, well, you didn't follow its directions.
Either way, delete the custom folders from addons/
« Reply #2 on: August 30, 2016, 02:50:33 pm »
Thank you. I only unzipped the one
