Author Topic: Reverse a Command  (Read 5138 times)
Offline BlueNova
Reverse a Command
« on: September 01, 2016, 06:19:24 pm »
Hi, I've got a question. How do you, if at all possible, reverse a function or command? Such as have an action that reverses a command. I've tried using setOpposite and unless I'm doing it wrong it does nothing.
I've searched the forums and haven't found anything on this.
Thanks.
Re: Reverse a Command
« Reply #1 on: September 01, 2016, 06:40:20 pm »
Take a look at an example in the ULX codebase: ulx gimp
This should give you the basic syntax for setting a command's opposite. Basically, you need a hidden Boolean argument, and you need to check if you need to reverse the logic in your command's function.
edit: It would be nice, though, if you provided us a sample of your code and explained your use case better (see below).
« Last Edit: September 03, 2016, 08:32:39 am by Bytewave »
Offline Undercover Orange
« Reply #2 on: September 01, 2016, 07:52:08 pm »
I wonder if he means like a "ULX Undo" where it undoes the last ULX command executed. if so that would be cool if someone could get running smoothly.
~ Undercover Orange
« Reply #3 on: September 01, 2016, 09:11:01 pm »
