Author Topic: Do ULX Command when you change Job  (Read 7346 times)
Offline Alpha Universe
« on: September 05, 2016, 10:17:23 am »
Hello Ulysses Forum.
I have a smal question.
Is there a way to perform automatically ULX commands when I change my Job in DarkRP?
I need that, because I want if my admins change the Job to "Admin on Duty" they should automatically cloaked and goded.
Is there a way to do that?
Thanks for your help!
Alpha Universe
Re: Do ULX Command when you change Job
« Reply #1 on: September 05, 2016, 01:19:08 pm »
I've moved this to off topic as it is not a ULib/ULX question as much as it is a DarkRP.
That being said, I know there are customchecks in DarkRP, but I don't know if they are 'just' that, a check to make sure you have access to something before a job change is allowed, OR, if they could be used to set off a function once someone changes to a job.
I think customchecks expect a result though, true or false, before allowing someone to change into a job.
I'd recommend searching the DarkRP wiki or forum, instead of the Ulysses one.
« Reply #2 on: September 06, 2016, 07:26:21 am »
Ok Thank you. Than I'll try it on the DarkRP Forums.
