Author Topic: What does this error mean?  (Read 5676 times)
« on: September 06, 2016, 02:27:06 pm »
  1. local admins = {}
  2.
  3.
  4. function ulx.respond( calling_ply, target_ply, message )
  5.
  6.
  7.    for k,v in pairs( player.GetAll() ) do
  8.
  9.       if v:CheckGroup( "operator" ) then -- This will add all "operator"s, and higher (anything that inherits, change if you want).
  10.
  11.          table.insert( admins, v )
  12.
  13.
  14.       end
  15.
  16.
  17.    end
  18.    ulx.fancyLog( { target_ply, calling_ply, admins }, "Admins to #P: " .. message, target_ply )
  19.
  20.
  21. end
  22. local respond = ulx.command( "Chat", "ulx respond", ulx.respond, "#", true )
  23. respond:addParam{ ULib.cmds.PlayerArg, target="!^", ULib.cmds.ignoreCanTarget }
  24. respond:addParam{ ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
  25. respond:defaultAccess( ULib.ACCESS_OPERATOR ) -- Make sure if you change the admins in the group, you change this (unless you want operators to see messages, but not send them).
  26. respond:help( "Sends a reply to someone from the Admins")
  27.
  28.
  29. function ulx.liststaff( calling_ply ) -- I have this in just because I was bored. Use it if you want.
  30.
  31.
  32.    for k,v in pairs( player.GetAll() ) do
  33.
  34.       if v:CheckGroup( "operator" ) then
  35.
  36.          table.insert( admins, string.upper( "(" .. v:GetUserGroup() .. ") " .. v:Nick() ) )
  37.
  38.
  39.       end
  40.
  41.
  42.    end
  43.    local cadmins = table.concat( admins, ", " )
  44.    ulx.fancyLog( { calling_ply }, "Currently connected staff: #s", cadmins )
  45.
  46.
  47. end
  48. local liststaff = ulx.command( "Utility", "ulx admins", ulx.liststaff, "!admins" )
  49. liststaff:defaultAccess( ULib.ACCESS_ALL )
  50. liststaff:help( "Displays a list of all connected admins." )
  51.
  52.
this is the script I'm using, pretty self explanatory (and simple), and this is the error I get when using respond:
] ulx respond
[ERROR] addons/ulib/lua/ulib/shared/commands.lua:890: attempt to index field 'type' (a nil value)
  1. __fn - addons/ulib/lua/ulib/shared/commands.lua:890
   2. unknown - addons/ulib/lua/ulib/shared/commands.lua:1296
    3. unknown - lua/includes/modules/concommand.lua:54
Now, even if I try just doing "ulx respond " with a space in the console, I get
[ERROR] addons/ulib/lua/ulib/shared/commands.lua:985: attempt to index field 'type' (a nil value)
  1. unknown - addons/ulib/lua/ulib/shared/commands.lua:985
Liststaff works properly, I'm just having trouble with respond. What do I need to change?
Offline Bite That Apple
  • Apple Innovations 2010®
    • Fun 4 Everyone Gaming
Re: What does this error mean?
« Reply #1 on: September 06, 2016, 03:29:16 pm »
The big boys are viewing this threads, and have more experience then me, so maybe will be able to find the issue. Though, I recommend you tell everyone what line 890 and 985 are according to your current code.
Though my guess is fancylog or something.
« Reply #2 on: September 06, 2016, 03:32:29 pm »
The entire thing there is my script. The errors are happening in a different file due to this, though.
Also, good to see you back.
« Reply #3 on: September 06, 2016, 04:15:41 pm »
Note: it may be good to point out I'm on the prerelease version if Garry's Mod, don't know if it's necessary to state that, but I am.
« Last Edit: September 06, 2016, 04:29:42 pm by iViscosity »
« Reply #4 on: September 06, 2016, 04:42:39 pm »
I ended up just using the respond from here, but I'd still like why it wasn't working, as this was making me really angry...
Omg I figured it out...
  1. respond:addParam{ ULib.cmds.PlayerArg, target="!^", ULib.cmds.ignoreCanTarget }
  2. respond:addParam{ ULib.cmds.StringArg, hint="message", ULib.cmds.takeRestOfLine }
I forgot type=...
« Reply #5 on: September 06, 2016, 04:43:19 pm »
You're missing the key type for your parameter type. It should be blah:addParam{ type=ULib.cmds.SomethingArg, ... }.
« Reply #6 on: September 06, 2016, 04:44:17 pm »
Just as I said it :(
« Reply #7 on: September 06, 2016, 04:45:27 pm »
I was working on the reply as you replied.
Hey, we all make small mistakes, man. Believe me.
Offline roastchicken
  • I write code
« Reply #8 on: September 06, 2016, 07:11:36 pm »
I was absolutely baffled a few days ago as to why my timer wasn't working. I was about to wipe the server and do a fresh install when I tried joining and voila it worked. Sometimes you forget the simplest things...
