Author Topic: The Menu will not show any settings  (Read 4380 times)
Offline RealFairServer
« on: September 10, 2016, 06:18:47 am »
IDK why... The menu will not showing any settings / Adverts / Permissions etc...
I'm using the latest version... I have reinstalled few times, deleted the data folder but nothing works.
Error when i create the !motd:
[ERROR] addons/ulx/lua/ulx/xgui/settings/server.lua:751: bad argument #1 to 'insert' (table expected, got nil)
  1. insert - [C]:-1
   2. DoClick - addons/ulx/lua/ulx/xgui/settings/server.lua:751
    3. OnMouseReleased - lua/vgui/dlabel.lua:218
     4. unknown - lua/vgui/dmenuoption.lua:116
What is the problem??
Re: The Menu will not show any settings
« Reply #1 on: September 10, 2016, 07:57:23 am »
Hm... I've never actually seen this myself. It would be best to try to let the Team help you, but what I would do, personally, would just be to backup some data files, then completely wipe the server. There may be some addon conflicting with the xgui, or something, I don't know. Hope you can figure it out, because I have no idea as I've never seen this :O
« Reply #2 on: September 11, 2016, 11:24:04 am »
If you haven't already fixed it via a wipe, are you getting any errors in the server console during your server start / map change?
Offline bizofack
« Reply #3 on: September 19, 2016, 07:07:03 am »
I have the same the problem was. Remove ulx givemoney and ulx givepoints and it will work!
