Author Topic: Ragdoll Error - See two ragdolls using !ragdoll  (Read 8516 times)
Offline sodak
« on: September 12, 2016, 03:24:39 pm »
Hey Team,
i have a big issue, always i use !ragdoll or /sleep (on darkrp) or using donkies stungun swep i see, two ragdoll models. Here a screen from my issue:
The Stungun addon dont causes this. the simple third person, too got the same issue on my ttt server with custom models or the normal models.
Already asked on FP and darkrp forums and the normal answer is disabling keep corpses but that dont help me.
Maybe u have a solution.
thanks
with kind regards
Sodak
Re: Ragdoll Error - See two ragdolls using !ragdoll
« Reply #1 on: September 15, 2016, 04:19:13 pm »
Do other players in your server also see two ragdolls?
Offline sodak
« Reply #2 on: September 15, 2016, 05:50:45 pm »
Hey Megiddo, yes other user see it too... Sry i forget to write this little information.
It happens to me and to other users.
!ragdoll  /sleep or the stungun weapon. Using DarkRP and latest ULX.
It happens on my TTT Server, too with the normal models.
Offline sodak
« Reply #3 on: September 18, 2016, 04:53:39 pm »
Update:
I see it happens on every model.
I dont know the error... is it ulx related, or garrysmod related... my ttt server has the same problem while using stungun and pointshop models
« Reply #4 on: September 18, 2016, 05:01:40 pm »
It sounds like you have a conflicting addon that might be doing something with the CreateRagdoll function.
Can you please try running ULX on a server with NO other addons and see if you get this issue? Preferably Sandbox gamemode.
Offline sodak
« Reply #5 on: September 19, 2016, 01:57:26 am »
Thank u MrPresident, now i checked all up and saw that this Addon: http://steamcommunity.com/sharedfiles/filedetails/?id=308977650
But i need this addon and dont find the problem in the lua file (its just one^^)
I guess it has something to do with this line: (Probably u can help me to fix it that it works normal but without this view addon.. now i removed it from my server till i get a fix for that issue, the author is very inactive)   Update: hook.Add("Think","SetPlayerCamoAlpha",CheckPlayerStill)  the Think hook causes this if i remove think out of this it fixed but the model is not in full cloak mode just in the mode while moving
if SERVER then
   local function CheckPlayerStill()
      for k,v in ipairs(player.GetAll()) do
         if v:GetNWBool("CamoEnabled") then
            if v:GetVelocity():Length() <= 1 then
               v:SetNoDraw(true)
               v:SetNoDraw(false)
            v:SetNoDraw(false)
   local function CheckPlayerDead(ply)
      local CamoIsOn = ply:GetNWBool("CamoEnabled")
      if CamoIsOn then
         ply:SetNWBool("CamoEnabled",false)
         NPC_SwitchRelationship(ply,false)
   hook.Add("PlayerDeath","RemoveDeadPlayerCamo",CheckPlayerDead)
  (Its this Function that causes this)
if CLIENT then
SWEP.PrintName = "Active Camouflage"
SWEP.Author = "Master Pro11™"
SWEP.Slot = 2
SWEP.SlotPos = 1
SWEP.WepSelectIcon = surface.GetTextureID("camo/camo_wepselecticon.vmt")
SWEP.Primary.ClipSize = -1
SWEP.Primary.DefaultClip = -1
SWEP.Primary.Ammo = "none"
SWEP.DrawAmmo = false
SWEP.HoldType = "normal"
SWEP.Category = "Master's Weapons"
SWEP.UseHands = false
SWEP.Spawnable = true
SWEP.AdminSpawnable = true
SWEP.Primary.Automatic= false
SWEP.ViewModel = "models/weapons/c_pistol.mdl"
SWEP.WorldModel = "models/weapons/w_pistol.mdl"
local CamoActivate = Sound("camo/camo_on.wav")
local CamoDeactivate = Sound("camo/camo_off.wav")
local CamoMat = Material("camo/camo_shade.vmt")
local CamoOverlayMat = "camo/camo_overlay.vmt"
local CamoIconMat = "camo/camo_icon.vmt"
SWEP.Weight = 5
SWEP.AutoSwitchTo = false
SWEP.AutoSwitchFrom = false
function SWEP:PrimaryAttack()
self:SetNextPrimaryFire(CurTime() + 3)
local CamoIsOn = self.Owner:GetNWBool("CamoEnabled")
if SERVER then
self.Owner:SetNWBool("CamoEnabled",!CamoIsOn)
if CamoIsOn then
NPC_SwitchRelationship(self.Owner,false)
NPC_SwitchRelationship(self.Owner,true)
elseif CLIENT then
if CamoIsOn then
surface.PlaySound(CamoDeactivate)
elseif !CamoIsOn then
surface.PlaySound(CamoActivate)
function NPC_SwitchRelationship(ply,yn)
if SERVER then
for k,v in ipairs(ents.FindByClass("npc_*")) do
if !yn then
v:AddEntityRelationship(ply,D_HT,99)
v:AddEntityRelationship(ply,D_NU,99)
if CLIENT then
local colorMofify = {
["$pp_colour_addr"] = 0,
["$pp_colour_addg"] = 0,
["$pp_colour_addb"] = 0,
["$pp_colour_brightness"] = 0,
["$pp_colour_contrast"] = 1,
["$pp_colour_colour"] = 0,
["$pp_colour_mulr"] = 0,
["$pp_colour_mulg"] = 0,
["$pp_colour_mulb"] = 0,
local function DrawCamoEffects()
if LocalPlayer():GetNWBool("CamoEnabled") then
DrawColorModify(colorMofify)
DrawMotionBlur(0.1, 0.5, 0.01)
DrawToyTown(2,ScrH()/2)
hook.Add("RenderScreenspaceEffects","ShowCamoEffects",DrawCamoEffects)
local CamoOverlayID = surface.GetTextureID(CamoOverlayMat)
local CamoIconID = surface.GetTextureID(CamoIconMat)
local CamoIconSize = ScrH()/5
local CamoIconY = (ScrH()/2)+(ScrH()/5)
local CamoIconX = (ScrW()/2)-(CamoIconSize/2)
local function DrawCamoItems()
surface.SetDrawColor(255,255,255,255)
surface.SetTexture(CamoOverlayID)
surface.DrawTexturedRect(0,0,ScrW(),ScrH())
surface.SetDrawColor(0,0,0,255)
surface.SetTexture(CamoIconID)
surface.DrawTexturedRect(CamoIconX,CamoIconY,CamoIconSize,CamoIconSize)
hook.Add("HUDPaint","DrawActiveCamoItems",DrawCamoItems)
local function DrawPlayerMaterial(ply)
if ply:GetNWBool("CamoEnabled") then
render.ModelMaterialOverride(CamoMat)
hook.Add("PrePlayerDraw","DrawPlayerCamo",DrawPlayerMaterial)
local function UndoPlayerMaterial(ply)
render.ModelMaterialOverride()
hook.Add("PostPlayerDraw","UndoPlayerCamo",UndoPlayerMaterial)
if SERVER then
v:SetNoDraw(true)
v:SetNoDraw(false)
v:SetNoDraw(false)
if CamoIsOn then
function SWEP:SecondaryAttack()
return
function SWEP:Initialize()
self:SetWeaponHoldType(self.HoldType)
function SWEP:Deploy()
self:SetNextPrimaryFire(CurTime() + .2)
self.Owner:DrawViewModel(false)
function SWEP:DrawWorldModel()
return false
function SWEP:Reload()
return
I removed the Think Function and now it dont this error.
But now when i go in the camo mode i get not fully invisible its shows the material like moving in invisible.
i need a fix for make me full inviisible if i stand still and dont move.
Here is the video how the addon works:
https://www.youtube.com/watch?v=1uQ7KjrQI1k
« Last Edit: September 19, 2016, 03:48:00 am by sodak »
« Reply #6 on: September 19, 2016, 08:07:50 am »
I'm sorry, but we don't have the time to help you fix another author's addon either. Your best bet is to either wait for someone to help you here (there are some pretty smart community members) or take this support question to the workshop page for this addon and wait for the original author to post a fix.
Moving this thread to Dev Corner.
Offline sodak
« Reply #7 on: September 19, 2016, 05:19:37 pm »
thank u MrPresident u helped me alot with the test all addons thing. the problem with this addon its... inactive sadly and used very often on swrp servers. So i have to w8 for a community member.
I fixed it now so:
Its no double ragdoll, and im not full invisible... maybe i should try to implement the ulx cloak function but dk if this work. im wating for others hand. its better to w8 for answers from other coders :)
