Author Topic: ULX Player not authed  (Read 6509 times)
Offline Yoshie
    • @pump_upp - best crypto pumps on telegram !
« on: September 15, 2016, 04:08:38 am »
ULib v2.61
ULX v3.71
Game mode(s) I am having this problem on: TTT
As soon as a player connects to the server, the serverside console spits out the following error:
[ERROR] addons/ulib-v2_61/lua/ulib/server/ucl.lua:1095: attempt to call upvalue 'playerAuth' (a nil value)
  1. fn - addons/ulib-v2_61/lua/ulib/server/ucl.lua:1095
   2. unknown - addons/ulib-v2_61/lua/ulib/shared/hook.lua:110
    3. UniqueID - [C]:-1
     4. echoToAdmins - addons/ulx-v3_71/lua/ulx/log.lua:164
      5. fn - addons/ulx-v3_71/lua/ulx/log.lua:202
       6. unknown - addons/ulib-v2_61/lua/ulib/shared/hook.lua:110
[ERROR] Unauthed player
  1. query - [C]:-1
   2. fn - addons/ulx-v3_71/lua/ulx/base.lua:78
    3. unknown - addons/ulib-v2_61/lua/ulib/shared/hook.lua:110
Re: ULX Player not authed
« Reply #1 on: September 15, 2016, 10:07:30 am »
Delete ULX and ULib entirely and redownload.
Offline Yoshie
« Reply #2 on: September 16, 2016, 08:55:02 pm »
I've tried that several times, even tried installing different versions. I just get the same error. To uninstall I am deleting the ulib+ulx folders from addons and data, is there somewhere else I need to remove them?
EDIT: Something was screwy with my server install, I verified it using SteamCMD and that fixed the issue. Thanks for your help.
« Last Edit: September 16, 2016, 09:08:24 pm by Yoshie »
« Reply #3 on: September 16, 2016, 09:49:19 pm »
In my experience, this issue is caused with the PlayerAuth hook breaks. Since verifying it fixed it for you, you probably had a bad edit in your garrysmod/settings/users.txt file.
Offline allofmywutsteam
  • MNWO Owner
    • MNWO Discord
« Reply #4 on: August 23, 2017, 03:45:26 pm »
I'm not running a dedi-server, so I almost went down a rabbit hole trying to figure SteamCMD out. Luckily, you're comment reminded me to check for the settings/users.txt file which I seem to have deleted (in an effort to fix another problem), so I'm glad I got that fixed.
Thanks.
